whatcha guys think? silverado build
Old May 1, 2011 | 04:09 AM
slowlsx's Avatar
Default whatcha guys think? silverado build
truck is coming together nicely, been gather parts and now finally putting it together. just wanted to show you guys my build and hopefully get some criticism on some horsepower numbers and ET guess's? i really dont have any goals for the truck i just want to have fun with it. here is what i got in the build.
04+ rebuilt 6.0
ls9 Gaskets & ARP Head bolts & ARP Rod bolts
stock 317's W/upgraded valvetrain
EPP Blower Cam 232/240 595/608 115LSA
stock intake
Dual walbro's & 72lber's
3.42 Gears
Performabuilt 4l60 lvl 2 & Circle D 3600
295/50/16 MT Drag radials
Hallman MBC
3 bar SD tune
pump gas & devils own Stage 2 meth kit
KB racing front mount S475 1.32 A\R
im gonna run 10-15psi and let her eat. im guessing 600rwhp and a 10 second pass. i know my cam isnt the best option for a turbo but ive seen big numbers with this cam and it sounds pretty good so i figured why not.
Attached Thumbnails whatcha guys think? silverado build-photo-1.jpg   whatcha guys think? silverado build-photo-23.jpg   whatcha guys think? silverado build-turbomotor.jpg   whatcha guys think? silverado build-turbo6.0.jpg   whatcha guys think? silverado build-44409_113914511996257_100001331271207_88241_2968321_n.jpg
Old May 5, 2011 | 11:19 PM
kbracing96's Avatar
No respect for trucks, Coming along nicely bud!
Old May 6, 2011 | 01:26 AM
slowlsx's Avatar
Lol god I know right!
Old May 6, 2011 | 01:55 AM
stock48's Avatar
9 Second Truck Club
They will here pretty soon when a mild truck setup goes in a car......
Old May 6, 2011 | 07:02 AM
hellbents10's Avatar
LS1Tech Sponsor
Looking good, I love trucks!
Old May 6, 2011 | 08:10 AM
robbyredneck's Avatar
i'm subscribed.
Old May 6, 2011 | 10:31 AM
Sluggish's Avatar
Looks like a sweet setup, except that poor 4l60e is about to be put to death.
Old May 6, 2011 | 02:25 PM
nodrok's Avatar
Why the 3 bar tune for only 10 to 15 psi. Ive heard you lose alot of resolution if your running a stock ecu. Shes gonna roll out though I would guess youll be right in the rage your shooting for. i think you may make over 700 with your set up. Your trans will not like it though
Old May 6, 2011 | 03:34 PM
slowlsx's Avatar
I plan to leave some TM in there. If it holds for 6months I'll be happy. I don't run the crap out of the truck daily so it should be fine. As far as the 3bar, I'll be running more then 15psi once I get a new shortblock, don't wanna blow the motor and then haft to wait on a motor!
Old May 6, 2011 | 06:16 PM
Ericmck2000's Avatar
Sounds like my build.
Im going with a aes 390ci, tci 6x tranny, ~3.55 rear gears, and a procharger. Also using the snow stage 3 meth kit, 80lb/ers, and a single in tank pump..
Subscribed, let us know how it goes. Be waiting another month to get all the parts to start mine.
Old May 6, 2011 | 06:47 PM
slowlsx's Avatar
That will be my next motor with 80E and s480 or s488
Got everything installed cranked it up and it started right away but zero oil pressure . We have checked everything and can't figure it out. Only thing left to do is to replace the slp brand new oil pump. I knew it was too smooth of a install for nothing to be wrong.
Old May 6, 2011 | 06:50 PM
tripblackls1's Avatar
oring maybe?
did you guys crank it without the coilpacks plugged in first? i always do after a buildto make sure there is oil pressure
Old May 6, 2011 | 06:51 PM
btw awesome build, more and more lately ive been thinking of buying a ss truck and putting boost on it
Old May 6, 2011 | 06:54 PM
MUSTANGBRKR02's Avatar
Did you put the plug in back of the rear cover? Little plastic plug that looks like a barbell. Without that the top half of the motor doesn't get oil.
Old May 6, 2011 | 08:23 PM
slowlsx's Avatar
Yea fast trucks are awesome. Around here in Texas you never know what your gonna roll up next to. Anything from 9 to 11 sec single and crew cabs!!
We ended up finding the problem!
Old May 6, 2011 | 08:25 PM
slowlsx's Avatar
Yea e ended up finding the problem and that was it. We were testing Out another block we had here and figured out that was the problem! Should be making some test hits Sunday!
Old May 7, 2011 | 02:06 AM
I went with the ugly single cab extended bed... Nobody will ever expect it....
Old May 11, 2011 | 02:47 AM
slowlsx's Avatar
Yea it's always nice to have a sleeper!!
Put the tranny back in today, cranked her up and let her warm up.. She is camming pretty hard! Me likey!
Old May 11, 2011 | 06:49 AM
stock48's Avatar
9 Second Truck Club
How does that S475 spool? What ex housing, and wheel?
Old May 11, 2011 | 04:38 PM
slowlsx's Avatar
Havint driven it yet but I'll make videos As soon as I do! standard s475. has the big exhaust housing, 96mm turbine wheel inducer, 88mm exducer. compressor is the same. When should I expect full boost on 10psi
