TR230/224 with a D1
Old Feb 23, 2004 | 06:38 AM
Slowhawk's Avatar
LS1Tech Sponsor
Question TR230/224 with a D1
Any huge downfalls to doing this?I figure it would bleed cylinder pressure which is what we want for now till the AFR's come out.Then we'll use a blower Cam.
Old Feb 23, 2004 | 12:04 PM
BIGBOS's Avatar
It being that big on a stock motor and reverse split isn't going to help much...is it 112lsa as well?
Old Feb 23, 2004 | 02:49 PM
Slowhawk's Avatar
LS1Tech Sponsor
It's a H/C car at 10.8-1 compression.This is temporary till we get the AFR's so hp is not the biggest thing we want.It's actually a 111 lsa.
Why buy Cams twice?
Is there any reason why we couldn't run it for now?
Old Feb 23, 2004 | 02:52 PM
BIGBOS's Avatar
That comp is dangerous waters as well, is he running an alky injection kit?
That cam will bleed off some major boost......
I blew a head gasket at 10.6:1 comp with 6psi with my D-1SC with my current baby cam in my 346 motor.......
Old Feb 23, 2004 | 02:59 PM
Slowhawk's Avatar
LS1Tech Sponsor
Yes,I understand the the compression but will tune around that.His motor only has 180psi when hot and is a forged bottom end.I've run timing as high as 26 degree's on stock 10-1 engines and 93 gas that have lasted for years so far.So 20 degree's of timing would be a good start.For now I would like to see the bleedoff which will directly drop the cylinder pressure and have the Head act like a lower compression setup.
Old Feb 23, 2004 | 05:47 PM
PurEvl's Avatar
Its a 360 forged bottom end, 110.3 lsa for the cam, 170 psi last compression test. Just thought I would through that out there
Old Feb 24, 2004 | 11:52 AM
PurEvl's Avatar
ttttttttt
Old Feb 24, 2004 | 11:56 AM
BIGBOS's Avatar
110 is even worse........
I would suggest changing the cam if you plan on having a worthwhile blower setup.....
I was making 6psi with my D-1SC and my current cam at 10.6:1 comp, when I swapped heads to my current TEAS from my MTI's my boost dropped to 4psi total.....you could see around that PSI most likely with the 3.6" pulley......
