New Personal Best ET
Old May 8, 2011 | 10:01 PM
WS6HUMMER's Avatar
Default New Personal Best ET
Last time I went to the track in the fall of last year I went a 10.33 @ 130. I knew my setup had more to give and the tune could use a little leaning out. Went back to the track this Saturday & ran a 10.09 @ 134.27 with a 1.46 60' on 13.5#'s on 275 Hoosier DR's (3632# with me). I really think it would have went 9's but I was having issues with my wideband not logging after the first pass so I couldnt adjust the A/F (it was fat anyway). Also the car was pulling the wheels & kind of bogging so I knew I needed to leave a little harder but for some unknown reason the 2 step would only let me leave @ 3500, when I set it all the way up to 3900. Anyway, stock motor is still hanging on strong & I actually got a an even higher trap speed of 135.52 on one of my 10.1 passes.
I plan on going back in the fall with no changes other than figuring out why my 2 step wont let me leave any higher.
Old May 9, 2011 | 04:34 AM
yessir's Avatar
how much boost to run those times?
Old May 9, 2011 | 08:57 AM
LS1RedZ's Avatar
Congrats on the new PB.
Old May 9, 2011 | 09:06 AM
MUSTANGBRKR02's Avatar
It says 13.5#'s in his post.
Old May 9, 2011 | 09:10 AM
skyhighsami's Avatar
no title here
Reading is fun-damental
Old May 9, 2011 | 10:04 AM
WS6HUMMER's Avatar
Thanks
Old May 9, 2011 | 10:06 AM
WS6HUMMER's Avatar
I've been thinking about why it wouldnt rev past 3500, and I'm pretty sure the converter may be too tight. Gonna talk it over with my converter guy and see if he thinks loosening it up will be the cure.
Old May 9, 2011 | 01:44 PM
TracyRR's Avatar
Congrats!! Nice build
Old May 9, 2011 | 01:49 PM
Nitroused383's Avatar
Add in some timiing on the footbrake, it will help bring it up on the converter. Seems like guys says anywhere from 30-40 degrees. Always a good feeling to set new personal best, congrats!
Old May 9, 2011 | 05:03 PM
WS6HUMMER's Avatar
Thanks
Thanks. I can only get it to foot brake to 2000 and just get out of vacuum, if I add more timing in on the foot brake do you think it would push my converter further once I get on the brake? Right now it refuses to go higher than 3500 and even though I have the boost set for 13# it spikes higher @ around 15# but drops to the correct amount once the car starts moving.
Old May 9, 2011 | 05:41 PM
TurboTerrorLS's Avatar
i just read your entire build thread. great work!!
Old May 9, 2011 | 07:16 PM
WS6HUMMER's Avatar
Thanks, I appreciate that.
Old May 9, 2011 | 07:18 PM
robbyredneck's Avatar
what did you lean it out to?
Old May 9, 2011 | 07:27 PM
WS6HUMMER's Avatar
I was shooting for 11.6 but my HPT interface wouldnt record the AFR after the first pass. Thats weird because I connected my laptop to the interface a few minutes ago and its seeing the wide band and my fuel pressure gauge through the interface, it just wont stand alone log those inputs for some reason.
Old May 9, 2011 | 08:11 PM
yeah mpvi will not stand alone log aux's. i have the same problem with my car scaring the **** out of my laptop at full song and it freezes up. good to hear leaning it out gave you some more hp. mine seemed to respond well also. keep posting on this thread , i would like to see your progress.
Old May 9, 2011 | 08:20 PM
WS6HUMMER's Avatar
Thanks.
I have never had a problem logging aux's until now, my interface (by its self) has always logged auxiliary inputs with no issues. Leaning it out helped a little but adding timing in, 1 degree at a time helped too.
Old May 9, 2011 | 09:26 PM
did you recently install beta? bill told me it wasn't gonna log and it sure doesnt.
Old May 9, 2011 | 09:33 PM
1CAMWNDR's Avatar
That's awesome Hummer. Except the transbrake/2-step/convertor thing.
Congratulations.
Old May 10, 2011 | 05:32 AM
Originally Posted by WS6HUMMER
Thanks
Yes Phil on here has stated that while on the converter he shoots for 12.5-12.8 AFR and anywhere from 30-40 degrees of timing to help get up on the converter. You want to make as much N/A torque as possible before you get into boost.
Old May 10, 2011 | 09:36 AM
WS6HUMMER's Avatar
I did a few months ago when I tuned a ford, I forgot all about that, thanks for reminding me.
Congratulations.
Thanks
Ok, Ill give it a try. I tried the trans brake last night without the 2 step just to make sure I didnt have a defective 2 step & it hung @ 3500 for a while and then all of the sudden flashed up to 4200. I don't think its the 2 step but I have to get it tuned to bring in the boost way faster, it took 6 seconds to get it to make 4200. Also I need to figure out why the boost is spiking when on the brake, I saw 18# once the rpm hit 4200.
