Critique my build plan
forged 3.905 wiseco pistons
forged 6.125 rods
stock crank
rollmaster double roller timing chain
LS1 intake,TB
custom cam(dont have one spec'd out yet)
317 heads.
stock rockers w/trunion upgrade
TURBO system plans
truck manifold's, or headers
2.5" primary tubes
garrett 76mm .70 compressor a/r .96 exhaust a/r t4 flange
3" downpipe
a-a intercooler
turbosmart(or other manufatcturer) 45mm wastegate
^^ blowoff
my goal is maybe around 700hp on motor with maybe 12-14psi
do you guys think i should use this turbo or go slightly bigger? headwork?
any suggestions are welcome, i have lots of pitures of the turbo. its a street car.
i was basing my build off of hot rod mags 594hp 5.3 turbo build.
and it will be a 347
and i just cannot justify spending 300-400$ on an LS6 intake. i know it would be better but i can so spend that money in other places.
thanks guys.
any thoughts on the turbo and supporting components?
my transmission is good to go, my rearend will be, so will the frame
maybe if i have extra$$
but yah that turbo should make 700 at the crank no problem, i'd be a little worried about the A/R on the EX side though, what size is the turbine wheel?
