Best Spark plug wire for HEAT?
Old May 11, 2011 | 01:40 PM
Busy Mopper's Avatar
Default Best Spark plug wire for HEAT?
Ive run the msd 8.5s and the larger Taylor wires. And they both are getting too hot from my turbo manifold EVEN after i put heat sleeves around them. I wrapped my manifolds but before i did, it actually burned through the rubber and also punctured the feed to the spark plug......
Old May 11, 2011 | 01:51 PM
93formto98T/A's Avatar
If they are burning through your heat sleeves and the wires they must be contacting the manifolds. There are no wires or heat sleeves that will withstand prolonged exposure to red hot manifolds. You'll need to find a way to zip tie them away from the manifolds. I had this same problem in the past.
Old May 11, 2011 | 01:57 PM
fair enough. im sure the are contacting the manifolds on the bottom. they are really hard to see due to the design of my log
