Greddy ProFec, BSpec II issues
Old May 13, 2011 | 01:43 PM
JAX04's Avatar
Unless the directions say to install it backwards, im lost.
Answer me this, IF, i set the controller to 50% DC, then when the controller senses positive pressure, it should start cycling the solenoid, correct?
Old May 13, 2011 | 02:02 PM
TheREALSmokin04's Avatar
50% on which setting?
Without pushing the ****, just rotate the ****...that setting is your requested boost in % rate. Meaning if at max your turbo's push 30 pounds of boost MAX, than 50% would be 15 psi.
Push the **** once, that gives you the gain (if i remember correctly) which goes up to 35% total. The higher the number the faster the boost comes on. You can easily exceed your max boost with the setting that high. I have mine set at 19-20% for 18 psi.
Push it twice and it gives you start boost. This setting is determining when the controller takes control of the gates. This setting is set in actual boost #. It needs to be as close to the spring pressure as possible.
Then you have your overboost setting...it's screen is red. I set this for 2 pounds over my requested boost level. This is a neat function because if your first (boost %) setting is wrong or too high, this feature wont let the turbo's run away.
The next one is the retard for the safety feature...this setting detrmines (in %) how much boost the safety bleeds off when hitting the overboost. I used this to find 18 psi exactly. I set this to a max of 15% so I wouldn't overboost, and made pull after pull until i found the proper boost level. Then I set it at 19.5 psi with a release of .4%. So when it overboosts, the most I hit is 18.5 psi.
Old May 13, 2011 | 02:04 PM
JAX04's Avatar
I havent messed with the start boost, but after many attempts, i maxed the gain at 35% and the first option to 100%.
Nothing happened, lol
Old May 14, 2011 | 02:05 AM
If nothing happened then it's definetly hooked up wrong...or not working. I think it's hooked up wrong though. Still haven't said whether you're single or twin turbo. 100% is MAX boost, and 35% is full open as fast as possible...so that makes me think install error. Are you hearing compressor surge?
Old May 14, 2011 | 03:26 AM
TurboAv's Avatar
He is a single turbo. I think it's more likely the used controller isn't functioning correctly. Parts like this I try to buy new or save until I can afford new.
Old May 14, 2011 | 09:28 AM
JAX04's Avatar
Like has been said, I highly doubt its functioning correctly, However, i cannot verify this until somebody can verify if you can activate the solenoid by simply blowing into the controller reference line.
To me, it makes sense, but then again, i have no idea. Ive been JohnV would chime in here, or NicD.
Old May 14, 2011 | 10:55 AM
It's not a nitrous solenoid...it's not a function of open/closed. It's a slider or electronically controlled variable orifice. Did you run the vacuum line to the back of the control unit? Is the filter installed?
Old May 14, 2011 | 11:09 AM
JAX04's Avatar
yes, the vacuum/boost source is ran to the back of the controller with the filter installed, the filter is in great shape, looks brand new.
 Michael S. Palmer
Old May 14, 2011 | 06:13 PM
Also, the pressure source should be directly off the compressor housing, not the intake manifold.
Old May 14, 2011 | 06:15 PM
JAX04's Avatar
The pressure source for the Solenoid is coming from the compressor housing.
Old May 14, 2011 | 07:08 PM
TurboAv's Avatar
I say contact the Ebay seller and return it. Then buy a brand new one.
Old May 14, 2011 | 07:44 PM
  #32
JAX04's Avatar
already did, he offered an exchange first then complete refund. I can deal with that.
Old May 14, 2011 | 08:38 PM
  #33
TurboAv's Avatar
Good to hear. It sucks dealing with delays though.
Old May 14, 2011 | 08:41 PM
  #34
JAX04's Avatar
It does. But what are you going to do. Lol. I'm happy he's not being a jerk. The only thing that sucks Is I've not got to boost all week. Lol
Old May 14, 2011 | 10:46 PM
  #35
Sweet_SS's Avatar
Mine was hooked up via the intake manifold and worked perfectly.
Old May 14, 2011 | 10:47 PM
  #36
Sweet_SS's Avatar
Glad to hear the seller is being a stand up guy.
Old May 14, 2011 | 11:07 PM
  #37
JAX04's Avatar
I dont think he wants to ruin his 100% feedback, lol.
Honestly, ive been racking my brain trying to figure out how to bench test. Its been frustrating. Im not one to buy used parts, unless, 1. im getting a stupid *** deal, and 2. the seller has remarkable feedback ratings, ebay or here.
its a bummer, and like Turboav said, its a bummer to wait, but oh well. what can you do.
its going back monday, im going to overnight it.
Old May 14, 2011 | 11:30 PM
  #38
Johnv's Avatar
The only way i can think to bench test it would be to use a compressor with regulater, lower reg setting to say 20psi connect to greedy controller and tee to inlet side of solinoid then play with controller and see if you can get flow from the solinoid outlet to wastegate.
Old May 15, 2011 | 10:01 AM
  #39
I does work that way...but you don't want it to see vacuum. To each his own.
Old May 15, 2011 | 10:36 AM
  #40
Sweet_SS's Avatar
To my knowledge you want the controller to see vacuum. Please elaborate on this? Not being a PITA, just trying to get another person's idea is all.
