Spark plugs & injectors 6.0 f1 procharger set up
hey guys i im putting in a rebuild 6.0 forged engine into a 2000 trans am and i went with a lonnie fuel system and putting a F1 pro charger on it.
Im trying to find out what plugs i should use for the fi system??????
i was told to go w/ 60 lb injectors but someone just recommended that i go with 80's if any one has any knowledge please give me the heads up???
a 7 heat range plug should be pretty good, thread right below yours has a few people in it running ngk br7ef plugs. go ahead and get 80 lb injectors. if that is a dual pump setup those 60's will be maxed long before your fuel system will be and they shouldn't be any harder to tune in than the 60 lbers.
