Question about going from dual fans to a single fan.
So in preparation of installing a Procharger, I need to swap from the factory two fan setup (hi/low) to a single puller fan. My question is do you simply connect the low fan wiring, or is there a way to make it a 2 speed fan where it kicks on at one rate when the pcm set point for fan 1 turns on, then goes to a second speed when the requirements for fan 2 kick in.
I hope this makes sense.
Thanks.
Thanks.
1 Post
Spal make some kick *** fans... Come complete with there own harness and have zero to do with your PCM they come with their own temp sensor... Really nice fans really big tag to them but they have the ability to pull air through the intercooler and condensor and radiator..
I think it is Spals AP series fans.
