Oil line and fitting selection for my rear mount
Old May 18, 2011 | 06:04 PM
5.3-on-steroids's Avatar
Default Oil line and fitting selection for my rear mount
Hello, I have a 95 s10 with a 5.3 swap. Im mounting my turbonetics TC78 right behind the cab. I was looking into the different routes you can go as far as oiling and I think im gonna go with a turbowerx pump, but I would like to use it in a pressureized application and completely keep the engines oil out of the picture. So this is where I need help, how do you guys do your oil lines for this? I read on a website for motorcycle guys that you should run -4an line to the turbo and tee it off with a -6 line the bleeds off the excess pressure into the sump tank. ANy thoughts on this? I baisically need a checklist of things to order if you could. Thanks
