Will this cam work for a turbo build?
Old May 18, 2011 | 09:49 PM
hdkarmy's Avatar
Default Will this cam work for a turbo build?
It a Lunati 218/224 .581 in 561 ex 114 LSA. Was thinking of a 5.3 or a 6.0 at 12psi. A friend of mine has it in his n/a car, and wants to change to a bigger cam.
Old May 18, 2011 | 10:55 PM
98Z28CobraKiller's Avatar
Restricted User
Yes. Would be better on a 5.3 than a 6.0 as it's pretty small.
Old May 18, 2011 | 10:57 PM
z28hustle's Avatar
the ls6 cam works pretty well btw
Old May 21, 2011 | 12:44 PM
transaman98's Avatar
Hows about a 224/230 .581/.592 114lsa?
Old May 21, 2011 | 06:57 PM
Maas's Avatar
That would definitely be a good cantidate for a turbo cam. In an ideal world I would like to see closer to a 10 degree spread and a wider lsa(although a 114 is in the right range), but that would work.
Old May 21, 2011 | 10:48 PM
yessir's Avatar
i went with a 221/221 .575 114lsa in a 6.0 and couldnt be happier, power peaks at 5700 or so and holds flat until redline (6200)
