Where to plumb Tial MVS cooling ports?
Each wastegate has an inlet and outlet cooling port. I know they are not required except for racing conditions but they are there so I might as well use them right? I assume that I need to plumb it to actually get some flow through the unit. Any suggestions? One to each side of the radiator tank?
I AM PONDERING THE SAME THINK ON MY CAR!!!!
I was thinking of connecting the circuit to run in series through the venting ports on top of the heads, into the WG and then into the water pump...
