TC76 + 7lbs Dyno results
Obviously I am limited with the stock engine so this turbo works great for what I'm doing. The compressor will make around 96lbs/min of flow but the turbine side needs around 42lbs/min of flow to actually support the compressor. Hence why people see pretty decent gains going to a PT76GTS / 7675 (same thing) only when running past the TC76-78 turbine flow limits. The 7675 turbine flows 38-40lbs / min from what I can tell, which should be good for an extra 120+ hp efficiently.
