help me pic my turbo.
04 gto hope to stay under 4000 lbs
Forged 347. And va speed turbo cam
Goin to run afr heads. 225s or 230s if. I buy them new.
4l80e. 3400 circle d verter... gforce engineering rear end parts and coilover kit...
The goal is to go strong 9s in the car. And get in the mid 140s trap speed.
Give me ur input guys. Think I am on the right track for the turbo... seems to be a good size and not to huge. But makes big power and spools decent..
This is goin to still be a street car but will not be a daily driver so I still want some good spool...
Thanks guys!
It will fit real nice under my Jimmy.
I didn't think you had room for a BW???
If you were closer, I'd let you try my CompTurbo 80mm.
It's 10.25 long and 8.125 round on the compressor with 79mm T4.
Little expensive compared to a box BW.
I'll post a pic of it next to the TC when I get it.
They make a PT80 along with the PT88.
i will make it fit some how..
got the TC sitting here at work with me so i can bubble wrap the hell out of it...
More input guys.. thanks!
Any input on this guys...
I am super pleased with his customer service so I will be buying from him. ..
-82mm won't do 1500-
S480 w/87 mm turbine will do mid 9's at 140+ in 4400lb full size truck.
-383 gen 2 with afr 195's, shifts at 6500. 234/234 108 lsa, carb'd single plane
NicD does low 9's in his Fbody with 76GTS.
I like this calculator -Squirrel
Got to make sure its ready for a bigger motor... everything else will be good want to make sure the motor is also....
We will shoehorn a good size unit in there
