E85 or stick with pump gas?
Old May 27, 2011 | 11:34 AM
JRENIGAR's Avatar
Originally Posted by gsxr1k2
I dont agree with that. When I switched I had to adjust pe and the ve tables quite a bit. I've got a couple hours of tuning into it.
thats what I was thinking...
Old May 27, 2011 | 11:50 AM
IT_SS's Avatar
Originally Posted by stock48
I just switched my truck to E85 vs gas/meth and now run at 12psi what I ran before at 14psi. The power gain, and response is ridiculous. A local WRX picked up almost 100RWHP at 28psi switching from C16 to E85. Im at 6000' and the extra oxygen in the E85 is helping things more than it would down low, but the gain still has to be huge. I sure wish I could run my truck on E85 out in Ca...
I feel your pain... on 1 effing E85 station in Los Angeles
Old May 27, 2011 | 12:14 PM
98Z28CobraKiller's Avatar
Restricted User
E85 is the ****. If you can get, do it. It is safer than pump, you can eliminate the meth and you will be ale to tolerate more timing for more power. There is no single value that I am aware of that would allow you to switch in the tune. It will require a complete re-tune.
Old May 28, 2011 | 01:51 PM
jdaniels's Avatar
You can ballpark it by chaning the stoichiometric value in HP Tuners and EFI Live (found under 'Mixture' in EFI Live) to 9.6 to 10.0 depending on the estimate ethanol content (yes, it's different in many places). If you are just looking to have a safer fuel you don't really have to molest your PE/VE tables that much (if any). If you are looking to take FULL advantage of the power benefits, you should re-tune. I've been running e85 since 2006 exclusively.
Old May 28, 2011 | 04:23 PM
gsxr1k2's Avatar
Im assuming your not running FI? ^^^ Thats a lot of bs imho. My car needed around 25% more on the ve tables in spots.
Old May 28, 2011 | 04:45 PM
NicD's Avatar
7 Second Club
Im assuming that your not also not running FI? ^^^ Thats a lot of bs imho. My car need around 25% more on the ve tables in spots.
If you are not changing out injectors and your tune was correct before and the only thing you are doing is changing to E85 than it's not BS. That single change will take care of a majority of the necessary fueling adjustments. The other VE changes should be relatively small and the timing adjustments would be obvious.
Old May 29, 2011 | 03:12 AM
stock48's Avatar
9 Second Truck Club
I ended up adding about 40% to the VE table, messing with the PE multiplier, and leaving the stoitch alone. Couldn't get it to run right with the lower stoitch. I'm running 1 bar MAF at 16psi so it's a botch anyway, but it's super crisp, and AFR is where I want it.
Old May 29, 2011 | 03:14 AM
stock48's Avatar
9 Second Truck Club
Sounds like a nasty combo! Have you made to Bandimere, or douglas with that beast?
Old May 29, 2011 | 07:08 AM
gsxr1k2's Avatar
No it's it's still in it's infant stage lol. Hoping to run Douglas soon.
Old May 31, 2011 | 01:33 AM
Dragframe's Avatar
Curious to see what kyles truck does in Douglas with your old hairdrier.... If he dont leave before he goes.
Jordan is gunna run 13's at 160mph lmao
Old Jun 1, 2011 | 02:30 PM
LS1RedZ's Avatar
Is E85 alright to run with a stock tank? Ive heard mixed things about this regarding it eating a tank up. I have Lonnies dual pumper kit with SS lines.
Old Jun 2, 2011 | 01:21 AM
  #32
skinnies's Avatar
Quite a few people run e85 and the stock tank.
Old Jun 2, 2011 | 04:08 AM
  #33
stock48's Avatar
9 Second Truck Club
I just put my truck back on 91 oct today getting ready to head out to Ca. Major power loss in and out of boost. Only plus is truck idles smoother cold. Sounds like a Top fuel dragster on cold start up with the E85.
Old Jun 2, 2011 | 04:21 PM
  #34
madball's Avatar
I am strongly considering an E85 tune on my current build. The station about 2 miles down the road from my place has E85. I still don't know if I should run 80, 95, or 120 injectors though. Currently I have 60's and know they won't be enough. Also I wonder if any of the mail order tuners will have an E85 base tune to get me started.
Old Jun 2, 2011 | 06:35 PM
  #35
99SS-T's Avatar
What kind of fuel lines are yall running to withstand the E85? I have been reading that you need SS but I cant imagine that everyone here has done that.
Thanks
Old Jun 2, 2011 | 08:11 PM
  #36
bad6as's Avatar
Well this makes me think. I'm going to get tuned this Monday. I have a 4301 magnafuel pump and fic 108 lb at 58psi injectors. Looking for 1100hp at the fly wheel. Also I have meth injection. Should I stick with gas or do I have enought for e85
Old Jun 2, 2011 | 08:18 PM
  #37
evo462's Avatar
Thanks
Stock
