Another Question for Meth Users:
Old May 25, 2011 | 01:17 PM
MrDude_1's Avatar
Default Another Question for Meth Users:
i have often wondered if you increased the head pressure on the system, and ran a smaller nozzle to keep the flow equal, would you see an even larger decrease in air temps?
In otherwords, with the volume of meth constant, if the pressure drop between the meth line, and the air intake was larger, would the meth show a larger decrease in intake air temp?
I know as a liquid, it doesnt compress like a refrigerant would, but do you see any change from doing this?
Old May 25, 2011 | 03:48 PM
Johnv's Avatar
You should get better atomisation and improved meth distribution,
I'm using 2 nozzels instead of 1 big one and a 250 psi pump for this reason.
