A lot of Horsepower and Vacuum Pump?
Old May 17, 2011 | 10:57 AM
dreamls1's Avatar
Default A lot of Horsepower and Vacuum Pump?
Do i need a vacuum pump for 1500hp or are there other ways to vent the pressure? What is everyone running?
Old May 17, 2011 | 04:31 PM
atomicfusion's Avatar
7 Second Club
When I ran E98 and a wet sump I had to run a pump, when I switched back to dry sump with C16 I no longer needed it.
If you need one, I have a belt driven one I'll sell you
Old May 17, 2011 | 05:28 PM
dreamls1's Avatar
How much you looking to get for it?
Old May 17, 2011 | 07:56 PM
7 Second Club
if you are really interested I can get pictures, but I have over $700 in the pump, bracket, pulley, etc, I'd take $400 for all of it. Mine is a mechanical pump for high end applications.
this pump
this pulley
a $100 bracket and a relief valve that was like $50.
and it has already been in the 8's
Old May 18, 2011 | 07:13 AM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
That's a great deal on that pump assembly! Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old May 25, 2011 | 12:52 AM
highpockets's Avatar
this pump
this pulley
Do you happen to have any pics of the pump,mounted on the engine ? I assume the pump bolts in front of the pass side cylinder head ? Driven off the tensioner pulley or ??? Thanks,have the same setup on mine,just trying to verify before I spend twice what I should for the bracket !
Old May 25, 2011 | 06:25 AM
Fireball's Avatar
its always a good idea...I run a star vacuum pump on mine
Old May 25, 2011 | 04:37 PM
KILLER-LS1's Avatar
ive been interested in installing one as well, I just dont know where to mount it on an F-body with front mount turbo and alt. in front of the passenger head....
Old May 25, 2011 | 05:06 PM
HSESWS6's Avatar
If he doesn't want it I would be interested in the set up. What side did you have it mounted on? Also if you had a pic of the bracket that would be sweet.
