induction question
Old May 28, 2011 | 10:01 AM
spaulsen's Avatar
Default induction question
i am building a twin turbo camaro and have a question. i was originaly going to use a fast 102mm intake and fast 102mm tb but my tuning guy didnt think the intake would take all the pressure of the twins. we have now went with a carb style intake with elbow, 160# injectors. my question is will i be able to use the tb? will it bolt to the elbow or will i have to buy a different tb? thanks guys, Shawn
Old May 28, 2011 | 03:42 PM
djfury05's Avatar
the TB will probably be too big.. you would need something around 90mm depending on the elbow opening.. take some pics of what you have so far
Old May 30, 2011 | 08:28 AM
spaulsen's Avatar
any1 else have an answer?
Old May 30, 2011 | 11:27 AM
CarsandWomen's Avatar
FAST intakes are pressure tested up to 60psi, if your running more boost than that id like to hear more about your setup.
without part numbers and manufacturers on your parts nobody can give you a real answer
