Procharger low boost question
Old May 28, 2011 | 08:09 PM
jattgunman's Avatar
Default Procharger low boost question
I recently installed a p1sc1 on my 2001 camaro ss using a 320 procharger
pulley and ~6" crank pulley and can't seem to get it to boost..at idle the
vacuum is at 18 and when I rev it the needle goes up to about 10 vacuum
but never goes into the boost side of the gauge...the source for bypass and
gauge is the brake booster line
Old May 28, 2011 | 08:21 PM
MadIceV8's Avatar
Customizing Director
Are you just reving the car or actually driving the car? You need to be driving the car (putting load on the engine) to build boost.
Old May 28, 2011 | 11:57 PM
jattgunman's Avatar
The blow off keeps going off under any load but I can't figure out why it's noy staying closed. Perhaps the blow off is defective? How can I diagnose this issue
Old May 29, 2011 | 12:11 AM
ChevyChad's Avatar
8 sec potential, 12 sec slip
As stated above... you need to be driving it to build boost. You won't see boost at all by just revving it.
Old May 29, 2011 | 12:41 AM
jattgunman's Avatar
Yea this is while in driving though, the blowoff just keeps blowing off under any load
Old May 29, 2011 | 12:49 AM
MadIceV8's Avatar
The blow-off valve stays open with vacuum and closes as you start building boost. If you want to test and see if leaving the valve closed makes any difference... just disconnect the vacuum line from it and plug up the line.
Old May 29, 2011 | 04:07 PM
jattgunman's Avatar
So I took off the vacuum line from the blow off and the blow off starts to go off while I raise the Rpms, so it has to be a defective blow off
Old Jun 10, 2011 | 09:45 AM
Zeke34's Avatar
Hey guys, I think I might be having this problem with my car as well and was wondering how fast I should be driving, while performing this test. My car is an M6 and I'm running a 3.70 8 rib headunit pulley with a 7.65" 8 rib crank pulley.
