no search luck - please explain boost referenced fuel regulator?
8 sec potential, 12 sec slip
However, I almost wonder if this may create some sort of false boost reading tho if there is any sort of pressure from the blower in the system that is being blocked out by the throttle blade..
I would say that it should be. Just place it as close to the manifold as possible.
I'm thinking how boost would blow the elbow right off my throttle body at mild throttle - compare that to what a vacuum hose going to the regulator would feel - should probably consult a regulator manufaturer for design confirmation.
