PSI Question
Old Feb 25, 2004 | 03:57 PM
JESTERSS's Avatar
Question PSI Question
I have a used 4 PSI ATI on order and I was wondering if I should up the boost and change pulley, the fuel injectors, and get a tune, or if I should just install what I have. What PSI do you guys consider safe on an LS1 with stock internals and compression?
Old Feb 25, 2004 | 04:00 PM
BIGBOS's Avatar
You can put the 3.6" pulley on it which will get you around 7-8 psi......you will probably see 5 or 6 due to the LT headers.......
But I would upgrade to 42.5LB injectors if you do that at the least and make sure you get a good tune.......
Old Feb 25, 2004 | 04:02 PM
dynedta's Avatar
chronic masturbator
i would 1st install what you have and get the bugs out if there is any (hopefully not) and then upgrade, most will say 5-7 psi
good luck
Gary
Old Feb 26, 2004 | 01:17 AM
BudH's Avatar
I installed a 3.6 inch pulley with headers and got 7 - 8 psi.
Old Feb 26, 2004 | 01:21 AM
BIGBOS's Avatar
Thats about right.........were you running LT headers?
Old Mar 14, 2004 | 12:00 PM
JESTERSS's Avatar
Is there a good place in or around Houston where I can get the 3.6 pulley and the injectors?
Old Mar 14, 2004 | 10:57 PM
BudH's Avatar
I have a 3.6 (like new) I'll sell you. E-Mail me if interested.
