Forged LS3 Twin PT66 Trans Am Build
#50
Well... the deal for the turbos/intercooler went sour. Long story...
On to other news; I have decided on going with a single instead, either a PT88 or billet 8884. I bought some used OFI turbo headers for a single setup.
Anyways, got the k-member in, figured we could just drop the motor in from the top.
#54
Sorry forgot to update here...
I ordered some goodies the past couple of days:
Speed inc aluminum fuel cell (bolts into stock location)
Aeromotive Eliminator Fuel Pump
Aeromotive Pro-Series Boost Reference EFI Regulator
PTM Throttle Body, 95mm
L92 Edelbrock Victor Jr
Edelbrock Fuel Rails
ARP Flywheel Bolts
GM Pilot Bearing
GM Knock Sensors w/ Bolts
GM non TCS throttle cable
Strange Bolt-In Shocks, Single Adjustable, Rear
BMR Lowering Springs, 1.25" Rear
BMR Sway Bar w/ Polyurethane Bushings, Hollow, 25mm, Rear
BMR Swaybar Brackets
McLeod Direct Bolt-In Clutch Master Cylinder
PRW Water Pump
-20AN water pump bungs
31x12x4 Ebay intercooler
28x19x3 Double Pass radiator
Some of the parts starting to come in...
Got to work on her some today... got the rear suspension and rear end in. Also got my new McLeod master in.
New intercooler mocked up.
ARP Flywheel Bolts
GM Pilot Bearing
PRW Water Pump
#58
Got the new T56 magnum mainshaft in the TR6060 today. Props to buddy pipes for helping me out. Went through all the gears, and it works. All that's needed is to cut the mainshaft a few inches, and make a linkage for the shift rail.
Unassembling everything off the front:
Case off with the stock mainshaft in there:
Stock T56 input shaft (left) vs stock TR6060 input shaft (right):
T56 Magnum mainshaft (left) stock TR6060 mainshaft (right):
Getting it all back together with the T56 magnum mainshaft:
All back together:
All back together:
