Vertical radiator with an AC condenser
I am kicking around the idea of doing a turbo setup that'd be too big to keep the radiator in the stock location, but want to keep my air conditioner.
Thoughts?
I see braided lines on the driver's side - what are those for?
The passenger side are to/from the condenser?
What radiator did you use?
Thanks!
the second pic shows a lil on how i did that
the drive side braided line are for the trans cooler
the passenger are from the condenser
the radiator is a custom from griffin
i seen one guy that used a smaller condenser his name is Willizm on here
I assume you had enough room for puller fans with the radiator vertical? What fans did you go with.
This is what I did too even though I didn't go vertical with mine...same concept. I moved mine back to the Condenser slot with more angle laying in some c shaped aluminum brackets. Bought a 12 x 24 condenser if I remember correctly.
