I have three short questions
Im building A stock bottom end 01 turbo ls1 with a tu1 cam. hope to be in the 500-550 whp range.
Is a ported or high volume oil pump necessary. should I get one?
Will I gain anything from a pair of 317 heads or will the stock heads be fine.
Where should I place my wideband sensor if my wastegate is routed back into the down pipe. before the gate dump into the dp or after. thanks
317's lower the compression ratio, always good for FI but with your low power goal theres no point in going with em unless you dont have heads already.
placement of the wideband needs to be atleast 12 inches behind the turbo, the wastegate or its dump tube does not play into this in any way
