stock water pump and high hp?
Old Jun 16, 2011 | 06:47 AM
TermnEatr's Avatar
Default stock water pump and high hp?
I'm gonna be runnin 15 lbs from my d1 on my 370 shooting for 7 to 800 hp any high hp FI cars out there runnin stock water pump?
Old Jun 16, 2011 | 07:19 AM
HydroStream6's Avatar
Most of us run the stocker.
Old Jun 16, 2011 | 07:29 AM
93formto98T/A's Avatar
Stocker is a solid performer unless you're running sustained high RPMs. 1200rwhp here with no issues.
Old Jun 16, 2011 | 08:19 AM
The Alchemist's Avatar
UNDER PRESSURE MOD
The LS2 c5 corvette water pump is a direct fit, and I thought I read that it flowed like 15% more than the ls1 f-body pumps.
Old Jun 16, 2011 | 08:52 AM
TermnEatr's Avatar
cool I might have to look into that. But for now I'll stick to my stocker just asking alot of questions cause I'm tryin to save as much money as possible to help finish the build thanks guys!
Old Jun 16, 2011 | 07:07 PM
koolrayz's Avatar
Stocker here
Old Jun 16, 2011 | 09:08 PM
KILLER-LS1's Avatar
im running the edelbrock pump
Old Jun 16, 2011 | 09:10 PM
mikeyc34's Avatar
i was wondering the same thing. thanks for the post and the replies.
Old Jun 16, 2011 | 09:17 PM
kmracer's Avatar
the fact that you work for them may or may not have something to do with that...
Old Jun 16, 2011 | 09:52 PM
NemeSS's Avatar
Stock wp on 600rw hp for bout 5yr now.no probs. With 160° tstat
Old Jun 17, 2011 | 02:18 AM
blue00ZZleeper's Avatar
700+ here with the LS2 water pump. Grab the LS2 one so when you get tired of belt slip and you get asters bracket, you already have one lol I think with the LS2 one you need to pull the pulley forward just a bit.
Old Jun 17, 2011 | 10:39 AM
Aster's Avatar
Not sure if these are referring to the same pumps or not...
The water pumps I use for my bracket system are from the 2005+ Corvette's which require the pulley to be pulled forward about 3/8". These are used on all the corvette engines for that period, LS2, LS3, and LS7. These do have the same housing as the previous LS1/LS6 pumps though.
Old Jun 17, 2011 | 12:57 PM
UNDER PRESSURE MOD
Yeah, my bad. I meant to say 2005 ls2, but wrote c5.
Old Jun 17, 2011 | 01:46 PM
AFASTYZFR1's Avatar
Stock pump here
Old Jun 17, 2011 | 03:38 PM
TermnEatr's Avatar
what oil pumps are yall running? I'm sure I will need to upgrage that bad boy.
Old Jun 17, 2011 | 04:58 PM
LS1RedZ's Avatar
Have the exact same setup (370, D1, 15psi) and I have the stocker.
Old Jun 17, 2011 | 08:29 PM
dreamls1's Avatar
Stock
Old Jun 17, 2011 | 11:08 PM
NemeSS's Avatar
Self ported stock oil pump w spring shim. 65psi cold 60 hot.same 600rw car
