Pumping Losses question
Old Jun 16, 2011 | 01:59 PM
wormus's Avatar
Default Pumping Losses question
Hi, I have a 402ci LQ9 with a TVS2300 making 14psi boost. Compression ratio is 9.5:1 and it's making 617hp at the wheels (about 750 at the crank).
The blower is overdriven but with a smaller 2.7" pulley will make 17psi. Trouble is I'm told timing cannot be advanced past 4 degrees to take advantage of this.
My tuner says 14psi allows more timing and makes the best power. I have suggested adding water/meth injection and he says it will not make any difference at 17psi. He thinks the problem is due to a restriction on the exhaust side and what I'm experiencing is pumping losses.
My heads are Trickflow 225s.
Does this sound plausible?
Old Jun 16, 2011 | 02:02 PM
XtremeDime's Avatar
What do you have for headers, etc? Those trickflows should be getting the exhaust out of the engine just fine.
Old Jun 16, 2011 | 02:14 PM
wormus's Avatar
Headers are 1" 7/8 long tubes into dual 3" exhausts. Cam spec:
224 intake
232 exhaust
585 lift intake
600 lift exhaust
114 LSA
Old Jun 17, 2011 | 01:34 PM
wormus's Avatar
anyone?
Old Jun 17, 2011 | 04:51 PM
corpserodeo666's Avatar
Do you have problems with vacuum or something? Maybe that could be a reason why he is talking about pumping losses.
