Turbo motor BS3 issue
The wideband works, map, tps, water, air, all the sensors have readings in the BS3. Timing is at 20, crank reference set to 350. I have went up and down with the timing with no change. I just recently noticed that I only had a 100rpm window on my rev limiter so I opened that up to a 500rpm window. I could use some help, the pcm section here is useless.
427lsx (8.5cr)
ngk 7 plugs
atomizer 225lb injectors
Thanks for any help
P.S. called BS3 directly and they said they do not answer tech questions about THIER product, you get refered to vendors......Could not believe it!
The BS3 model is: you ask questions of the dealer that sold it to you, they do not have a tech line. The dealer can normally help you with new set up issues. Like GM, you go to the dealer with new car issues, you don't call GM direct.
Kurt
I am using truck coils and harness that came with my 01 5.3 motor. I am going to try the BAL thing now.
If you read this document;
http://bigstuff3.com/pdf/Ignition%20...0rev%201.2.pdf
Bottom of page 16 top of 17 walks you through the process of checking the cam and crank synchro event phasing. I don't know enough to tell you what you need to do to fix it, but the red dot is outlined as a problem.
Hopefully 427 can help you out more with this one. Good luck!
1. Check for leaky injectors.
2. Try swapping your outside two cam sync wires on the sensor, if this works the BAL part will turn grey and the small dot will rotate when cranking.
Kurt
Kurt
