Cometic v. MLS
Old Feb 26, 2004 | 11:41 PM
buschman's Avatar
Default Cometic v. MLS
I'm looking for head gaskets. I know I read a thread somewhere recently that listed the different gasket thicknesses and told you what your subsequent C/R would be. Does anyone have this info?
What's the difference between cometic and MLS?
Thanks,
Mike
Old Feb 27, 2004 | 12:57 AM
BIGBOS's Avatar
I'm running cometics on my setup, I would rely on them to lower the compression as much as the heads......get some 73cc 5.7L or 6.0L heads, that will drop you down to under 9.5:1 comp.....
Old Feb 27, 2004 | 05:58 AM
smokinHawk's Avatar
Cometic gasets are MLS (multi-layered-steel)
on newer models Gm uses a MLS gasket, these mls (stock thickness) are cheaper then cometics gaskets
so only get cometics if you need a special thickness.
Old Feb 27, 2004 | 08:34 AM
30thta436's Avatar
Before you run out and by mls gaskets, you need to inspect your heads. 98-00 heads had a notch in the side of the head. Visible from outside the motor.
They look like a place to pry the head off of the block with a prybar. If you have the notches and use the mls gaskets you will leak coolant. Every 98-99 I looked at had the notches. About 50% of the 2000's I looked at had the notches. I guess mid year 2000 GM deleted the notches that they say don't exist. If you have the notches run the cometic gaskets.
Old Feb 27, 2004 | 08:59 AM
HUGGER ORANGE SS's Avatar
Good point 30thta436
How is that G-Trim holding up to the 70,000 impeller rpms??
Clint
Old Feb 27, 2004 | 09:04 AM
smokinHawk's Avatar
IF i read right bushman is getting 6.0 heads (01-03 aluminum) so the notches wouldnt matter in his cas, but if somebody else does with stock 98-99 heads yes.
Old Feb 27, 2004 | 09:07 AM
Tiago's Avatar
Anyone else have any info on how the 99 heads leak with the MLS gaskets?
Doesn't make anysense to me how it would matter unless it was an unperfection in the deck/head mating surfaces. I really haven't looked at my car to notice this notch though.
Old Feb 27, 2004 | 09:10 AM
buschman's Avatar
You are correct sir, but thanks for the heads up. When I pull my 00 5.7L heads where should I look for that notch? Just for curiousity's sake.
Does anyone know where I can find prices on these Gaskets? How about info on subsequent C/R for the varying thicknesses?
Mike
Old Feb 27, 2004 | 11:53 AM
30thta436's Avatar
Clint
It is 77,000 rpms, and it is holding up good. No problems with it.
The engine is another story. Broke another piston and cracked the block. I found the limit of the stock fuel pump and t-rex fuel system. I was running out of fuel over 6400 rpms and it detonated again. I have the engine out of the car again. I have another block I'm assembling. I also am getting rid of the t-rex and stock pump and running a dual intank setup, I built. I hope to have the car running tonight or early in the morning. Then I will dyno tune again tomorrow, then the track on Sunday. Thats the plan at least.
How is your ATI holding up. Last I saw you broke 600RWHp.
Old Feb 27, 2004 | 11:55 AM
30thta436's Avatar
Tiago, Have a look at the thread I posted 2 years ago. There is pictures and an explanation.
By the way I have seen 2000 f-bodies with the notches in the head. I have also seen some 2000's without the notches. So I imaging that there was a casting change somewhere mid 2000.
https://ls1tech.com/forums/showthrea...hlight=notches
Old Feb 27, 2004 | 12:24 PM
smokinHawk's Avatar
call cometic at 1800-752-9850
for the gm gaskets look them up on www.gmpartsdirect.com
Old Feb 27, 2004 | 02:16 PM
S_J_H's Avatar
just use the Cometics or the MrGasket brand MLS.
I am using the Mrgasket MLS. Part #3143G.
They look like Cometics, embossed sealing areas and full nitrile coated.
Sell for about 65$ each through Summit.
I have 98 heads and yes they have the notches.
Steve
Old Feb 27, 2004 | 04:43 PM
buschman's Avatar
Thanks for the heads up guys. This is the info I was looking for.
Mike
Old Feb 28, 2004 | 12:50 AM
30thta436... Man how many times are you going to pop something in your motor??? This is the 3rd time right?
You will like the duel Walbro pump setup..
The car is running strong with 602 rwhp and 11psi..
Clint
Old Feb 28, 2004 | 06:45 PM
30thta436's Avatar
Clint
Yep 3rd time. This time it broke 2 pistons and cracked the block. I used my spare block. I wasn't going to build it right now and go forged internals and put the t-trim on. But there is a local event coming up on the 14th of March we need to attend. So we rebuilt it stock (which we can do quickly). We just put the Vortech ice box on tonight. Will put the pumps in tomorrow.
Sounds like we have about the same cars except yours is ATI and mine is Vortech. Do you think you can get any more out of the blower, or is it tapped. How much are you over spinning it now?
Old Feb 28, 2004 | 11:37 PM
I spun mine to about 67,000 impeller rpms. The blower is holding up very nice. If I spin my blower up more I'll need to buy another Cogs pulley which will run me about 75 bucks.. Sure I could do that, just have not yet. My 112 LSA Cam is hurting my numbers.
Clint
Old Mar 1, 2004 | 12:42 AM
30thta436's Avatar
Clint
Looks like we are the pioneers for these blowers. Get a better cam in there and pulley down. I would really like to see what these blowers are fully capable of. I think I am at the limit of the G-trim. But I think with the ice box I might be able to hit 650RWHP. We will see sometime this week, when I get back on the dyno...
Old Mar 1, 2004 | 01:37 AM
BIGBOS's Avatar
I was thinking about the whole pulley changing thing........the thing that will hold us back from making the pulley size changes is the availability of the COG belts in certain sizes, the 73T 31T I'm currently running like Jeremy uses a 37" belt and the tensioner pulley has to be put under the belt instead of over to make it fit......
I'm sure I'll spin the blower to the max..........and then some
Old Mar 1, 2004 | 01:41 AM
30thta436's Avatar
What pulley and boost level are you at now?
What kind of power is it making?
