Head build up
Old Feb 26, 2004 | 11:51 PM
buschman's Avatar
Default Head build up
Take a set of bare 6.0L heads. What valvetrain components would you equip it with? I'm thinking while the heads are off, hardened pushrods, 918 springs, ARP head studs(or maybe bolts). I'm thinking stock rockers will hold up to 12 psi. How about new hydraulic lifters? How difficult and useful would a roller cam be on a blown car? I started a whole other thread about the gasket issue.
Your advice is really appreciated.
Mike
Old Feb 27, 2004 | 12:55 AM
BIGBOS's Avatar
Usually the heads will come w/a double spring, my TEAs did, I would get the pushrod deal, I'm still using the stock rockers, and I dunno where my PSI will be at, a lot higher then 12..........I will eventually go yella terras
If you are going to do a cam now, get something that you plan to put in your future motor.....it will save time..........
Old Feb 27, 2004 | 06:00 AM
smokinHawk's Avatar
i think your rockers will be fine, just get springs and pushrods.
and head studs. I go with the hex head studs instead of the 12 point though, i hate my 12 points, the suck getting on and off.
Old Feb 27, 2004 | 10:19 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I would do:
2.02, 1.57 valves, will work with stock seats
get stage I porting, mine flow 299/220 at .600 hardly spectacular and I'm at 746rwhp thru a T400 trans.
Old Feb 27, 2004 | 04:42 PM
buschman's Avatar
Has anyone ever tried a home port job? Any super expensive special tools needed to do that? Or is it a combination of know how and good old fashioned elbow grease? Shawn, who I bought the heads from, suggested that you can dremmel out material from the inside to give yourself the 74cc chambers. Question is what to dremel out? I figured if that's all it takes for the 74cc chambers maybe porting the valve ports is a similar feat. Perhaps someone could educate me if I'm way off base or not.
Mike
Old Feb 27, 2004 | 10:38 PM
IRVINEWS6's Avatar
How much for a pair of stage I 6.0L heads, double springs, adn rods?
