Best cam for blower
Old Feb 26, 2004 | 03:04 AM
Blown98's Avatar
Default Best cam for blower
Hey what would be the best cam for my car, i also dont plan on getting heads for a while too if that helps. Also i drive my car daily but i do want a wicked cackle would like to get a good amount of power, any suggestions would be great, thanks guys.
Old Feb 26, 2004 | 05:30 AM
NA$TY-TA's Avatar
A 218/224 mid 540's to 550's lift on a 114 should do a good job if you didnt want to go to big on the cam or a 224/230 with 570's thru 590's on a 114 would do good. As long as you run good valve springs you should be fine....... I would recommend replacing the timing chain and oil pump while your in there.
Kyle
Old Feb 26, 2004 | 11:00 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I like the sound of Kyle's second example, you can live and grow with that 224/230//114 for a long time. It will have a lope and folks will know you are cammin' but it won't be as lopey as the hotcam. Should push you over 500rwhp no problem, you already have headers?
Old Feb 26, 2004 | 11:24 AM
RICE ETR's Avatar
Turbo Addict
I agree.. you want something opposite of a turbo cam. something that favors the exhaust in lift/duration.... and keep the LSA around 114 as mentioned.
Old Feb 26, 2004 | 04:22 PM
HUGGER ORANGE SS's Avatar
Pro Stock John You making fun of my Hotcam??
Old Feb 26, 2004 | 04:37 PM
Blown98's Avatar
I dont have headers but i plan on getting them after the rear end, as for the cam i do like Kyles second idea and when i get closer to getting one ill check back with you guys but i just wanted to get a rough idea on a good cam, How does the Hotcam do with a SC?
Old Feb 26, 2004 | 04:46 PM
NA$TY-TA's Avatar
Not so good because it is on a 112 LSA. It bleeds off to much boost that you worked so hard to create.......
PSJ, I finally made my cam choice. I called Comp and they took all my information and Chris told me i would be very happy with this cam in my new motor.
Comp XER 230/236 .592/.602 on a 114+4
Thay said it should lope just like i want and make power to 6500rpm's wich is were i want to shift (Should MAX out the D1-SC w/ the ASP Cog Pulleys)
Kyle
Old Feb 26, 2004 | 05:09 PM
LS1Tech Co-Founder
Make sense Kyle, I run a 230/236//115/+2 in my 348ci (not like your stroker) and my peak is probably ~7000 in my smaller motor.
Old Feb 26, 2004 | 07:41 PM
Inspector12's Avatar
TT-TECH Veteran
I have a FMS 224 230 581/591 114+4 I haven't installed it yet but Allen recomended it so I am sure it's going to run well with the Vortech.
Old Feb 26, 2004 | 08:30 PM
NA$TY-TA's Avatar
I called Allen at FMS and he told me to go with a 236/242 .595/.615 on a 114. That was a little bigger then i wanted to go and that was with the 383 stroker i was building also.
Go with the 224/230 on a 114 you will like it and it will make plenty of power and you will still have room to grow with it.
Kyle
Old Feb 27, 2004 | 12:59 AM
BIGBOS's Avatar
What size are you doing for the new motor, similar to me?
If that cam you choose works well and makes good power that might be a good future upgrade for me to get rid of the baby nuts cam.....
I was thinking 236/240, might be slightly too big though.......
Old Feb 27, 2004 | 02:34 AM
NA$TY-TA's Avatar
Bos,
AP Engineering Iron Block 370ci. Diamond Coated pistons, Eagle rods, ARP L19 rod Bolts and Head Studs, and Main Studs. I will be using that cam and 317 casting 6.0L head w/ MLS 6.0L head gaskets
Old Feb 27, 2004 | 09:03 AM
Some Big Cams Quoted here. The HotCam is alright. But with the 112LSA it does bleed out fresh unburned air, not perfect for a blower.
Still making pretty good power though.
Clint
Old Feb 27, 2004 | 10:41 AM
Slowhawk's Avatar
LS1Tech Sponsor
I just installed a FMS 224/230 on 114 in a customers car and it has no lope idling at 900rpm..
Old Feb 27, 2004 | 11:22 AM
LSs1Power's Avatar
Im running the FM7 224/230 .587 .593 114 cam and it made great power N/A(almost 400rwhp with no TB or pulleys). Its my daily driver and it idles at 900rpm with no problem. Im getting the D-1SC soon and im going to run 8psi for now.
Old Feb 27, 2004 | 12:12 PM
BIGBOS's Avatar
Nice, I'm looking forward to see how our motors do with these COG pulleys......
Old Feb 28, 2004 | 12:53 AM
I like mine
