Need a specific Hobbs switch
Old Jun 19, 2011 | 01:37 PM
wreckwriter's Avatar
Question Need a specific Hobbs switch
I need a Hobbs switch with a 2 terminal Metripack 280 connector set at .5 or 1 psi (best bet would be one of each). I've tried digging the epoxy out and adjusting a 4 psi switch but I have no way to test the psi other than in car on the drag strip (which eats up one of my 2 time runs each time I test it).
Anyone know where I can get such things?
Thanks!
Old Jun 19, 2011 | 02:39 PM
Johnv's Avatar
The pressure switch that comes with the basic coolingmist meth inj kit ,is an adjustable switch, not sure if it will go that low though.
Old Jun 19, 2011 | 02:45 PM
That's my problem, I have no way to know how much to adjust it or to check it.
Old Jun 19, 2011 | 04:25 PM
twinturbo2's Avatar
u can get a cheap air regulator and a boost gauge hook it all up adjust switch off the car may not be exact but u can save alot of time my two cents
Old Jun 19, 2011 | 06:11 PM
Yea, but by the time I get all that and plumb it up I'm 50-100 bucks into a $25 switch. I need it to be fairly accurate, it came with a 4 psi switch, big lean spike, found a 3 psi, still same. I need 1 or .5, not +/- 2 psi.....
Old Jun 19, 2011 | 06:21 PM
kmracer's Avatar
bench test it. im assuming you have an air compressor?
Old Jun 19, 2011 | 06:51 PM
Same answer as above. Yea, I have a compressor, I don't have a bench boost gauge or a regulator to go to .5 psi.
I kinda thought one of our vendors might have either a switch or the equipment to test with accuracy. Maybe I was wrong?
Old Jun 19, 2011 | 07:10 PM
ModularTurbo's Avatar
call me
Old Jun 19, 2011 | 07:14 PM
Originally Posted by ModularTurbo
call me
At the number on the site in your signature?
Old Jun 19, 2011 | 09:13 PM
kjhallex's Avatar
Wheres the best place to buy hobs switches?
Old Jun 19, 2011 | 09:15 PM
Busy Mopper's Avatar
google search it. i got one that comes on at 2psi and it works perfect i tested it with my compresser putting out like around 5 psi so it came on
Old Jun 20, 2011 | 04:02 AM
Johnv's Avatar
If this is for a meth kit, get a progressive controller and dial in what ever you want.
Old Jun 20, 2011 | 06:10 AM
No, its for a fuel pump.
I found what I needed. Thanks for all the replies and ideas!
Old Jun 20, 2011 | 12:06 PM
123quattro's Avatar
FWIW, Summit sells a switch that is adjustable from 2-12 psi.
Old Jun 20, 2011 | 03:29 PM
FastKat's Avatar
This might be helpful - it will at least give you a part number to search for.
http://content.honeywell.com/sensing.../catswitch.asp
