Anyone running two fuels/tunes?
Old Jun 21, 2011 | 08:27 PM
IT_SS's Avatar
nodrok, thank you for your input, it really does help.
aside from the injector tables in the tune, what would be the proper way for changing fuel? I plan on keeping the stock tank (plastic), and I'd imagine I can't just pour in x gas and switch go x tune while y fuel is present, correct?
Old Jun 21, 2011 | 08:29 PM
IT_SS's Avatar
deion82, I want no part or what your building, reading your post just made me tuck my tail, what the hell are you building? 16 injectors? sheesh
Old Jun 21, 2011 | 08:32 PM
buick_lsx's Avatar
Will vcm scanner let you switch tunes, or do you have to haventhe suite version? I'm at the same place right now with pump and e-85
Old Jun 21, 2011 | 08:47 PM
kmracer's Avatar
you need VCM suite
Old Jun 21, 2011 | 09:05 PM
rotary1307cc's Avatar
Originally Posted by FMX05
Something like the ID2000's would be able to do either, provided the tuner would build 2 completely separate tunes including injector tables.
+1
the IDs would handle it no problem
Old Jun 21, 2011 | 09:17 PM
FMX05's Avatar
You would want the tank to be as empty as possible. A little E-85 in your gas will make it run leaner, and gas in your E-85 richer. If it's less than 2 gals and you fill up I wouldn't worry about it. The key would be to make the gas tune extra safe, that way if there is some E-85 left it won't lean you out too much. You'll be running the car on E-85 almost all of the time with the ability to use gas if you can't find E-85 if I'm understanding you right. So the gas tune can be really conservative.
Old Jun 21, 2011 | 09:20 PM
nodrok's Avatar
This is the simple yet very involved solution. 2 separate fuel systems separate tanks. Run a stock and run a cell. 2 tune ecu 8 injectors for gas 8 for e85 flip the witch for tune/fuel cell run for 5 minutes while switching fuels. This can work, but who wants to put an additional fuel system? No one. Maybe th ID2000's can do it. I dont know. I would consult a credible tuner. They will know for sure. Make sure you get a second opinion because some tuners may not want to open that can of worms. I am interested because I will sell my 96 pounders and buy the ID200'2 get some new pumps fuel lines (teflon instead of rubber) and do what you are doing. I was going to do this originally but was talked out of it. I may see 800-900 AWHP out of my silverado ss after all.
Good luck
Old Jun 21, 2011 | 09:27 PM
FMX05's Avatar
Good luck
ID2000's have been made to idle in a stock DSM I believe. They are the end-all be-all of high impedance injectors right now. They are one of the few high impedance capable of making big power on E-85. Your twin fuel system setup would be more precise when switching fuels and tunes though.
Old Jun 21, 2011 | 10:22 PM
nodrok's Avatar
Maybe the end of the year if all goes well. Ill be the guinnie pig. I will be some work but ill try the dual fuel for high performance setup. 2 busy working out of town now.
Old Jun 21, 2011 | 10:34 PM
IT_SS's Avatar
good info folks:
FMX05, other way around; 91 most of the time (very conservative) and E85 race duty (aggressive)
Nodrok, as I stated earlier, very helpful thank you.
So now it looks like it can happen, what would the fuel system be? will twin intake 225s, aftermarket rail and ID2000 suffice ( i know that just scratching the surface, I want to keep it general because it looks like other folks are interested as well)
Old Jun 21, 2011 | 11:29 PM
FMX05's Avatar
good info folks:
Well if that is the case just make sure to run it down pretty low before your fuel up with E-85. What is your power goal? Dual Walbro's doesn't go very far on E-85. If Dual Walbro's will get you where you want you might be able to get by with less injector.
Old Jun 21, 2011 | 11:47 PM
  #32
tripblackls1's Avatar
wow those id2000 injectors are 2k$ /whistle
Old Jun 22, 2011 | 05:47 AM
  #33
nodrok's Avatar
What power level? I have dual walbros. If you want big power you need trips. If i do my fuel system over again i may have gone A1000 just to make things easier.
Old Jun 22, 2011 | 06:41 AM
  #34
LS1NOVA's Avatar
Fuel Injector Connection sell the same injectors as the ID's for much less $$.
Old Jun 22, 2011 | 11:00 AM
  #35
JankesGTO's Avatar
Only way to accurately run e 85 is to test your fuel. I was having a hell of a time tuning for it. Once I realized I had e70 things fell into place. Just a little heads up
Old Jun 22, 2011 | 11:16 AM
  #36
Avengeance's Avatar
HPT kit $600... 2 tunes... best bet.
Old Jun 22, 2011 | 11:46 AM
  #37
IT_SS's Avatar
I saw that last night, I'd spend that on AFR heads befors injectors, but the are the injector to end all injectors, but I know there has to be a cheaper solution.
I'd like to trap 150 mph and get kicked off the track (10pt + T Tops = UGLY), I believe Mighty Mouse is running trips..
So you saying test the batch befor using/tuning for it? I understand E85 and Samuel Adams both have seasonal blends lol.
I think I may post this topic in the Tuning and Fuel forums as well
Old Jun 22, 2011 | 11:52 AM
  #38
deion82's Avatar
Good luck
I'm only running one fuel system. 1,200hp blown ls1 streeter. 16- 66lb injectors will have a better low end drivability over 8-160lb injectors. I just thought I'd post what I'm doing but I'll say no more. Good luck
Old Jun 22, 2011 | 11:53 AM
  #39
JankesGTO's Avatar
Well I didn't test mine, I guessed at it and lucked out but yes test your fuel if you can.
Old Jun 22, 2011 | 02:06 PM
  #40
IT_SS's Avatar
These injectors http://fuelinjectorconnection.com/sh...&productId=246 ?
Has anyone tried using dual bosch 044s?
