Updated ProCharger Model Specifications
Old Jun 23, 2011 | 07:58 AM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Default Updated ProCharger Model Specifications
NOTES
The stated figures are not absolutes, and may actually be higher depending upon the specific application.
These figures are based on stated peak airflows; actual obtainable power levels may be higher in well prepared engines.
Engine intake charge air temperature is the most relevant thermal measure (not SAE J1723) for supercharger installed on a vehicle, especially when intercooled; SAE J1723 does not address the impact of engine dynamics, engine compartment heat transfer, intercooling, or deficiencies caused by supercharger location.
ProCharger F-1
Base HP Range of NA Engine: 300-500 HP
Maximum Supercharged HP Rating: 1,050 HP
Maximum Airflow: 1,525 cfm
Maximum Boost: 38 psi
Inlet Diameter: 3.75 inches
Outlet Diameter: 3 inches
Maximum Impeller RPM: 70,000
Internal Step-up Ratio: 5.40:1
Self-Contained Oiling: Yes
Reverse Rotation Available: Yes
ProCharger F-1D
Maximum Supercharged HP Rating: 1,000 HP
Maximum Airflow: 1,500 cfm
Maximum Boost: 32 psi
Maximum Impeller RPM: 65,000
ProCharger F-1A
Maximum Supercharged HP Rating: 1,100 HP
Maximum Airflow: 1,650 cfm
Maximum Impeller RPM: 74,000
ProCharger F-1C
Base HP Range of NA Engine: 300-550 HP
Maximum Supercharged HP Rating: 1,225 HP
Maximum Airflow: 1,850 cfm
Inlet Diameter: 4 inches
ProCharger F-1R
Base HP Range of NA Engine: 375-550 HP
Maximum Supercharged HP Rating: 1,300 HP
Maximum Airflow: 2,000 cfm
Inlet Diameterw: 4 inches
Maximum Impeller RPM: 68,000
ProCharger F-2
Base HP Range of NA Engine: 425-600 HP
Maximum Supercharged HP Rating: 1,600 HP
Maximum Airflow: 2,700 cfm
Inlet Diameter: 4.5 inches
Outlet Diameter: 3.5 inches
ProCharger F-3A-121 NEW
Base HP Range of NA Engine: 500 – 850 HP
Maximum Supercharged HP Rating: 2,100 HP
Maximum Airflow: 3,100 cfm
Maximum Boost: 40 psi
Inlet Diameter: 5.5 inches
Outlet Diameter: 4 inches
Maximum Impeller RPM: 75,000
Internal Step-up Ratio: 6.24:1
ProCharger F-3A-123
ProCharger F-3R-131
Base HP Range of NA Engine: 600 – 900 HP
Maximum Supercharged HP Rating: 2,400 HP
Maximum Airflow: 3,600 cfm
Maximum Boost: 45 psi
Inlet Diameter: 6 inches
Internal Step-up Ratio: 5.63:1
ProCharger F-3R-135
Base HP Range of NA Engine: 650 – 1,000 HP
Maximum Supercharged HP Rating: 2,600+ HP
Maximum Airflow: 3,900 cfm
ProCharger F-3R-139
Base HP Range of NA Engine:700 – 1,000 HP
Maximum Supercharged HP Rating:2,700+ HP
Maximum Airflow: 4,000 cfm
Maximum Impeller RPM: 62,500
ProCharger F-4
Base HP Range of NA Engine: 900 – 1,400 HP
Maximum Supercharged HP Rating:3,200+ HP
Maximum Airflow: 5,400 cfm
Maximum Boost: 50+ psi
Inlet Diameter: 7 inches
Outlet Diameter: 5 inches
Maximum Impeller RPM: 55,000
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
