low HP/TQ on STS LS2 GTO?
I got it tuned but it seems really low. 380RWHP/400TQ @5PSI with a tc76 turbo. I was expecting almost 100rwhp more closer to 460-480rwhpwith this setup on 50/50 Meth. Am I wrong?
Your PSI numbers are coming from a compression test. Compression test results are influenced by compression ratio, but the camshaft profile also has a large impact.
Your ratio numbers are static compression ratio, they do not take into account the amount of stroke that the intake valve is open. A better way method of comparison is dynamic compression ratio, in your case the dish pistons plus a different cam reduced the dynamic compression ratio significantly.
Low compression + big cam = low compression test results.
Good side: If you are ever in a pinch, you can turn down the boost (or just stay off the throttle) and get away with running 87 octane.
Bad side: The car will probably be lazy out of boost, and fuel milage will probably not be as good as before.
As others have stated, the max power number should improve quickly as boost is increased.
The LS9 cam may not be the best option for a turbo, as it was designed for use with a pd supercharger.
