tig or mig
I got it for about $1300 with all the accessories brand new. Chinese welders have come a LONG way.
TIG IS FAR BETTER THAN MIG.
you can weld in your sunday best
if you miss the setting, you can control it easily with the foot pedal
it makes cleaner welds
it welds very quietly
no wire feed errors
can weld aluminum
the book gave guidelines on torch angle, distance,amperage, rod, tungsten type, etc, and it said practice practice practice.
I bought my tig welder without ever watching anyone weld and after 5 hours or so of welding different thicknesses of shim stock/like shim stock, and maybe a bottle of argon, I was able to weld my hotside and coldside 100%
And a MIG is far handier for general automotive use. Plus cheaper.
no wire feed errors
can weld aluminum
MIG is still relatively clean. But the same safety rules apply from exposure to the arc with regards clothing.
If you get the wrong setting, just change it
Clean weld is down to preparation more so than welding method.
I doubt anyone has ever been deafened by a MIG
Wire feed errors....occasionally it may be a problem, but only very occasionally
And only if you buy a more expensive machine.
MIG is cheaper.
MIG is faster
MIG will blast a weld with less preparation if needed on unclean metal. TIG will not
MIG is one handed, so tacking the workpiece is a doddle.
And generally I'd say more versatile for automotive use.
Also easier to produce a strong clean weld with MIG with little experience.
If you are only buying one machine for the workshop, for me MIG would always be my first choice. TIG as a second unit.
Unless of course you are buying it with very specific needs in mind.
People just get obsessed with TIG for work as the welds can look all nice when done by a skilled welder. As to whether the insides of those pipes also look so good, is another matter. Backpurging is essential if the inside isnt to go all crusty. With neat fitting MIG welds, that just doesnt happen.
MIG is cheaper.
MIG is faster
how about pulsing for thin sheet metal?
change the settings? when you are welding aluminum and the workpiece is getting hotter by the second thus requiring less input are you going to stop and wait for it to cool every 20 seconds or will you be continually changing settings at the machine? with tig you just feed less and less input at the foot pedal
nobody ever got deaf with mig. try telling that to your wife when you are welding in the middle of the night.
you never have wire feed errors with tig. with some stainless steel exhaust work (409 eg) you dont even need wire. you cant do that with a mig
tig welds look a lot better and that is important to some people.
most importantly, it is easier to learn to tig than to mig. because you have a lot more CONTROL, from the foot pedal, and you manually feed the wire as needed.
As for strength. We arent putting together aircraft or space rockets here. Show me a car part that has failed due to actual welding technique ( ie MIG or TIG ) then I'll believe that one is actually worth having over the other.
The simple fact is, such a scenario will never happen. The person doing it might do a ***** job, but that is not down to the welding machine or style of welding.
Obviously if you need to weld aluminium then there is no question the only option is TIG.
If you can get a dual machine MIG/TIG for sensible money, then yes that would be great. But even a decent Mig here would cost around UK £600 ( circa US$900 ) and a relatively basic AC/DC TIG UK £1200 ( circa US$1800 )
Unless you opt for the really cheap chinese stuff.
For general automotive and workshop use, MIG is still no 1 for me
