tig or mig
mig pros - easy, cheap ,fast, can fit in tight spaces
mig cons- does not look as pretty and less heat control
tig pros - show quality welds, awesome heat control, welds almost anything
tig cons- usually not very moveable and you need proper welding space (not easy to weld in cramped areas)
i always recommend a mig if its going to be your only welder, just because you can weld anywhere with it and not stuck to a workbench
MIG is still relatively clean. But the same safety rules apply from exposure to the arc with regards clothing.
If you get the wrong setting, just change it
Clean weld is down to preparation more so than welding method.
I doubt anyone has ever been deafened by a MIG
Wire feed errors....occasionally it may be a problem, but only very occasionally
And only if you buy a more expensive machine.
MIG is cheaper.
MIG is faster
MIG will blast a weld with less preparation if needed on unclean metal. TIG will not
MIG is one handed, so tacking the workpiece is a doddle.
And generally I'd say more versatile for automotive use.
Also easier to produce a strong clean weld with MIG with little experience.
If you are only buying one machine for the workshop, for me MIG would always be my first choice. TIG as a second unit.
Unless of course you are buying it with very specific needs in mind.
People just get obsessed with TIG for work as the welds can look all nice when done by a skilled welder. As to whether the insides of those pipes also look so good, is another matter. Backpurging is essential if the inside isnt to go all crusty. With neat fitting MIG welds, that just doesnt happen.
one pro is that alot of tig welders can be bought with as a plasma cutter combo unit.
A mig will do 95% anything you need on a hot rod and be more practical for day to day use.
Just try to lay under a car and hold a bracket with one hand and tack it with a TIG.
A TIG welder is best suited for welding parts on a work table with clean tight fits.
www.everlastgenerators.com
Ive never taken an actual class on TIG welding. Learned from doing it. After messing around I became ASME certified and went on to pipe fitting and making pressure vessels.. x-ray'd for some pretty strict standards. Now about 14 years later i dont weld as a profession anymore... but do teach people and have been asked to help teach at the local tech college which I respectfully declined.
Welding isnt the thing you need to know first.. When you weld you need to know the process... the thermodynamics of what you're welding. metallurgy is something you can read up on. It has a lot to do with what happens to the metal when you melt it and then it cools again.
Welding is the easy part, all you do it melt metal with electricity and glue it together. The cleanliness of your welds, the steadiness of your hand, the order in which you weld a complete pipe up.... all come from doing it over and over.
All this side info you can find online. Free. Read it, read all about it. Miller has its own forum. Then... practice, practice and practice. No school can substitute practice.... in fact thats what most of school is... practicing which you can do at home for free. Have a question? Ask online.... you get more answers than from one teacher at a school.
this along with lots of practice. i have been stick/mig welding for 20 years. tig is a lot of fun. however i have built several cars with just a mig welder. on my last build i just paid a welder 400.00 to tig up my hot side.
bottom line! if you have the money and time to learn. buy a tig machine. I will tell you it is not easy, it takes a lot of coordination, skill.
Ive seen people lay down a tig weld that rival that of a robot weld in only a few hours of learning it.. and then ive seen others that have been doing it for 20 years and still suck....lol.
