A LS Procharger hub that can take it.
A dual key damper hub that's extra thick where it needs to be. Made for use with a Jesel belt drive cam and a dry sump oiling system. You can also run a alternator with it. It accepts any standard ATI damper ring.... Oh and you can change the coge pulley to any size you want.
