Same WG,differant ci,turbo,cam,lower boost??
Old Jul 1, 2011 | 06:00 PM
SPRAYED 01's Avatar
Default Same WG,differant ci,turbo,cam,lower boost??
So I have put about 1000 miles on my new setup up so far to break it in. Tunes at speed inc next friday.
Same tial 50mm wg, same tru boost controller and settings as last year running a 347 with a tc78. Off the gate I would get 8lbs, off max setting 15.5psi.
I have a very safe base tune and I went wot for a short amount of time just to make sure im getting good boost before the tune.
Now with the same ls6 intake, same ported 241s but with a 232/236 cam insted of a 224/226 cam both a 115s im only getting 5lbs off the spring and 9.5 at max setting.
this is using a 370ci motor and a 80/79 billet wheel ball bearing comp turbo with a 1.32 ar.
Is this normal? It pulls really hard,feels smooth, just not nearly the boost I was running before.
Alex
Old Jul 1, 2011 | 07:57 PM
Snyper's Avatar
More ci consumes more air. The turbo is flowing the same amount but theres more area to fill so the boost(restriction) is lower. I bet the power is around the same or even more.
Old Jul 1, 2011 | 08:03 PM
Brad Campbell's Avatar
I agree with the above, but are you saying the gate is set with the same spring and it runs less boost? What size spring is in the gate?
Old Jul 1, 2011 | 08:19 PM
SPRAYED 01's Avatar
Yes Brad,gate is set up with an 8lb spring. Im only getting 5lbs. It gets there really quick but then stops building.
Old Jul 1, 2011 | 08:22 PM
Ok, regardless of displacement and flow vs. pressure the gate should hold the same boost. Are the gate and your boost gauge plumbed to the same source?
Old Jul 1, 2011 | 08:45 PM
SPRAYED 01's Avatar
No the gate gets it source from the turbo, gauge is off the manifold. Same as the last setup. I know there could be a differance but with the tc 78 and 347 last year it would be right at 8lbs off the spring.
Old Jul 1, 2011 | 08:50 PM
First thing I would do is adjust the plumbing so the gate and boost gauge are off the same source. Tie the gauge into the gate line off the compressor. I would suspect you will find that the gate is regulating to the 8 pounds, but that you potentially have a boost leak. I'm not quite sure what else would do something like this.
Old Jul 1, 2011 | 08:59 PM
SPRAYED 01's Avatar
I was thinking that there is a 3lb differance between what comes directly off the turbo compared to that actually gets to the intake. Ill try a boost leak test first.
Old Jul 1, 2011 | 09:09 PM
It is possible that there is a major pressure drop. Regardless it seems as though the gate is doing what it's suppose to. It'll be interesting to see what you find. Good luck.
Old Jul 2, 2011 | 06:47 AM
98Camarod's Avatar
I had all mine to the same boost source, that way I didn't have any variables as far as that goes.
Old Jul 2, 2011 | 07:05 AM
JAX04's Avatar
i noticed the same things, If i referenced my compressor housing for ANYTHIING it started ready boost early.
ive also got a An ebay IC, which is what i blame it on.
Old Jul 2, 2011 | 07:36 AM
98Camarod's Avatar
I never even gave it a chance to mess me up
Old Jul 2, 2011 | 10:07 AM
SPRAYED 01's Avatar
I have an ebay ic to.
Old Jul 6, 2011 | 02:17 PM
Snyper's Avatar
Ohh, I missed the 8# spring part..my bad.
Old Jul 7, 2011 | 11:22 PM
SPRAYED 01's Avatar
Ok, checked for boost leaks. Found a small one from a pipe to the ic. Fixed it, checked and cleaned all my plugs.
Same thing,i have a aem tru boost,i turn it to off which is the waste gate spring and I only get 5.5lbs. Its an 8lbs spring.
It pulls hard for being on a safe break in tune. Gets to 5.5 almost instantly also.
What else could it be?
Old Jul 7, 2011 | 11:33 PM
Johnv's Avatar
reference your wastegate from the manifold and i bet your back up to 8 ps.
The back pressure dynamics of the different engine /turbo combo are effecting when the gate opens, you likely have more backpressure in the downpipe than you had before with the smaller cubes.
Old Jul 8, 2011 | 11:11 PM
SPRAYED 01's Avatar
Ok referenced the gate to manifold with similar results. I get 6 maybe 6.2 off the spring but only 10 off the setting that got me 15.5 last year with smaller turbo and engine.
I wonder if somthing is going on with the waste gate.
Old Jul 9, 2011 | 11:57 AM
SPRAYED 01's Avatar
Anyone on this?
Old Jul 9, 2011 | 07:22 PM
Johnv's Avatar
Had a mate having similar issues, he had to have 20lbs spring to make 10 lbs boost.
He built a bigger downpipe and exhaust, and straight away was overboosting and had to add a second wastegate to control boost creep.
How big is your downpipe and exhaust , is wastegate plumbed back or do you run a screamer pipe ?
Old Jul 10, 2011 | 09:39 AM
SPRAYED 01's Avatar
3.5 dp to a 3 inch exhaust that has a cutout. The waste gate is open to atmosphere
