rear mount guys
Old Jul 11, 2011 | 04:20 PM
95batmobile's Avatar
thats just cooooool
Old Jul 11, 2011 | 09:51 PM
Blackbird's Avatar
so you ran the pipes inside the car???
Old Jul 12, 2011 | 06:29 AM
99ls1vert's Avatar
The pipe runs through the rocker panel, so it is surrounded by the inner and outer rocker. The only thing im concerned with is how hotthe pipe will get? I was not planning on running an intercooler but with the pipe there it wont get any air flow around it, so I ordered an intercooler last night,lol I just used a 3" hole saw to look inside and see if it was open all the way through and it was. Ill keep u guys updated on how it works out. Going to run a T70 with eathier 2.5" or 2.25".from what ive read, its sounds like the bigger tube will reduce the pressure drop from the turbo inlet side, but then again I think sts uses 2.25"?
Old Jul 12, 2011 | 08:03 AM
sswwweeet. thats cool. i think i got my mounting figured out too... ill post pics once i fix it...
Old Jul 12, 2011 | 10:11 AM
Blackbird's Avatar
that is an awesome find! please do keep us updated. if it works out I would totally do this as well.
Old Jul 12, 2011 | 09:31 PM
BlackChicken's Avatar
My setup, is tucked pretty high. My rear sway bar is even with my turbo.
Old Jul 12, 2011 | 11:00 PM
blackmagicturbo's Avatar
hows that little return pump work ? no smoke under accelleration ? check valve?
Old Jul 13, 2011 | 04:25 AM
Blozzard's Avatar
Nice!
Old Jul 13, 2011 | 05:29 AM
i just figured out that my exhaust is too far forward.... becasue the seay bar is in the way.. im gonna see if i can inch it back at all- hopefully it will be running tonight
Old Jul 13, 2011 | 09:59 AM
99ls1vert's Avatar
wow! thats tucked up in there nice!! Where does the tube go from the wastegate?
Old Jul 13, 2011 | 11:07 AM
lol thats what i was thinking
Old Jul 13, 2011 | 01:29 PM
  #32
99ls1vert's Avatar
Just a quick question but do you have to change the maf sensor to like a 2 bar or something?
Old Jul 13, 2011 | 03:35 PM
  #33
The tube is basically a dummy pipe except when the waste gate opens and then it opens up to a 3.5 exhaust tip to keep the rear of the TA to look normal.
Old Jul 13, 2011 | 03:38 PM
  #34
If your talking about the blue tube it was for my mbc, the dial was under the back bumper. I ended up taking that off and adding truboost.
Old Jul 13, 2011 | 04:20 PM
  #35
no your stock maf can stay
Old Jul 14, 2011 | 07:54 PM
  #36
https://ls1tech.com/forums/forced-in...l#post15153122
i dont feel like transferring all the pics.. so just click here lol
Old Jul 14, 2011 | 08:00 PM
  #37
Camaro9969's Avatar
Originally Posted by 95batmobile
hmmm maybe pics of how you all mounted the turbo? cause im lost...
watch out for ******** that like to steal the rear mount turbos!! trust me i know all about it.
Old Jul 14, 2011 | 08:02 PM
  #38
i always thought about someone doing that?! did that really happen to you?! that takes too much time for someone to try lol
Old Jul 14, 2011 | 09:02 PM
  #39
Camaro9969's Avatar
takes a lot less than you think w a cordless sawzall
Old Jul 15, 2011 | 05:25 AM
  #40
good grief.... that sucks man
