rear mount guys
Old Jul 6, 2011 | 09:44 PM
95batmobile's Avatar
Default rear mount guys
im running a t72 and have like 4 inches of ground clearance at the most. how much you guys got? did i do something wrong? cause i feel like thats not driviable
Old Jul 6, 2011 | 09:54 PM
Fbodyjunkie06's Avatar
Have you driven it like that before sucessfully?
Old Jul 6, 2011 | 10:23 PM
not yet. first test drive should be tommorow
Old Jul 6, 2011 | 10:30 PM
hawk584's Avatar
i have less then a beer can's worth of clearance ... and haven't hit anything yet
Old Jul 7, 2011 | 12:34 AM
hitmanws6's Avatar
Do the coke can test, i have 3 inch under the axle duals that dont scrape anywhere that just clear a can
Old Jul 7, 2011 | 05:21 AM
kk cool thats about what i got. thats a relief. i made up a brace and all just to keep the turbo as high as i could. ill post a pic of it tonight or tommorow it will prob make you guys laugh but i just threw it together last minute. it isnt a show car or anything lol
Old Jul 7, 2011 | 07:25 AM
99ls1vert's Avatar
I had the same concern but my car is also lowered, I only have about 2 inches of clearence
Old Jul 7, 2011 | 09:19 AM
3800SII's Avatar
I have found it helpful to mount the turbo as close as possible to the passenger side right over the axle. Brace the turbo to the body and add a flex pipe pre-turbine so the exhaust won't crack.This way avoids the standard mounting that you would use for the muffler. It can save a couple of inches if done right.
Old Jul 7, 2011 | 11:24 AM
have you hit anything? lol i would be scared with that
Old Jul 7, 2011 | 11:35 AM
ZL1Killa's Avatar
I haven't hit anything and have about 4~5 inches of ground clearance, I cannot fit a coke can under it...but its just missing it by about 1/2" maybe 3/4"
Old Jul 7, 2011 | 02:52 PM
99ls1vert's Avatar
Im actually trying to build a rear mount set-up right now on my convertible, so it has the extra sub-frame braces and its lowered. I tried to mock up some tubing and was going to use 2.5" oval which is 1.75" x 3". Even with the shorter pipe, I only had about 2 inches. So right now im stuck on how to run the cold side back up to the front.
Old Jul 7, 2011 | 03:05 PM
3800SII's Avatar
The biggest problem that you might have will be going up and down hills or when you back up over a bump. The suspension will be unforgiving in a lowerd car with only two inches of clearance. You might consider a front mount kit instead.
Old Jul 7, 2011 | 08:55 PM
well i took it for a test drive.. i have less than 2 inches.. i using a t72 thats pretty giant... but i have no idea how to mount it any higher???
i have it pressed up against the heat shield on the gas tank.. the only thing i can think of is cut the trunk out and put a piece of sheet metal up then route some piping there. hang the turbo where the trunk used to be. thats my only thing i can think of.....(im a fabricator but im outa options)
Old Jul 8, 2011 | 05:20 AM
hmmm maybe pics of how you all mounted the turbo? cause im lost...
Old Jul 8, 2011 | 06:16 AM
99ls1vert's Avatar
ya Pics! I thought about running the cold tube down the inside of the rocker panel, but the turbo will still be fairly low
Old Jul 8, 2011 | 11:04 AM
bumppp for some help
Old Jul 8, 2011 | 07:46 PM
hawk584's Avatar
Old Jul 8, 2011 | 11:38 PM
hmmm ok thanks for the pics... i think i will need to undo my exhaust hanger and raise the whole pipe then try and spin the turbo around a little more to get a little more
Old Jul 9, 2011 | 07:54 AM
99ls1vert's Avatar
awsome pics! thanks
Old Jul 11, 2011 | 07:17 AM
99ls1vert's Avatar
I solved the ground clearence problem, It actually turned out better then I thought it would. No more pipes under the car besides what will go from the wheel well to the the turbo
