those running 5.3's
Old Jul 17, 2011 | 09:28 PM
  #41
kellysmith's Avatar
its marked with yellow marker on the front of the block just under the head on the drivers side if ur block isnt to rusty that is
Old Jul 17, 2011 | 09:43 PM
  #42
southpaw0314's Avatar
there is no real way to tell without pulling a head to check the piston. unless the block is still in the vehicle you can check the 8th digit on the vin for a t(lm7) or a z(l59).
Old Jul 18, 2011 | 02:18 AM
  #43
Johnmaster's Avatar
MASS seller approved
If you absolutely had to you could find the volume of 1 cylinder with a liquid like how you would cc a head chamber.
Tip the engine so the spark plug hole is basically the highest point of the cylinder
Loosen the 2 rockers on the cylinder so the valves are closed.
Get the cylinder close to top dead center and fill with fluid (light oil or trans fluid.)
cycle slowly past tdc and the excess will run out (this leaves the combustion chamber volume left in the cyl.
Turn the crank 180 and fill with 600cc of fluid
If you are full or close to full its a 4.8.
If you can add another 65cc you have a 5.3
This would beat having to change a perfectly good head gasket just to figure out what you have.
