2-bar MAP sensor not reading above 105kpa
Old Jul 9, 2011 | 07:37 AM
The Alchemist's Avatar
UNDER PRESSURE MOD
Default 2-bar MAP sensor not reading above 105kpa
Maybe I didn't do something right, but I bought GM part # 12615136 which is the latest part number for the 2-bar MAP sensor. I simply installed it in place of the factory MAP sensor, then flashed in the 2-bar operating system via HP Tuners.
I'm doing some low/mid throttle and rpm tuning and notice that the map sensor never reads above 105kpa even when I stay in the throttle. It just flatlines at 105kpa, so something is not right.
Did I miss a step when I installed the sensor? Did I need to do something else?
Old Jul 9, 2011 | 08:08 AM
UNDER PRESSURE MOD
I figured it out. I needed to actually change my scanner settings and read the PID for MAP 2-bar instead of the stock MAP (SAE) sensor.
Old Jul 9, 2011 | 10:23 AM
T/A KID's Avatar
Glad you got it figured out, was going to mention that. Just converted mine over yesterday too.
