supercharger pulley
Old Jul 11, 2011 | 10:52 PM
catpue's Avatar
Default supercharger pulley
i'm building a 408ci metal block with all forged internals and 9-1 comp.,right now i have a vortech s/c with a 3.12 pulley and i want a little more boost,i had this system on a new 6.0 with 11-1 comp.that is the block i am building that i got a couple years ago and it was only running 7lbs of boost with that pulley,i also have a meth system installed ,l also have ported and polished 243 heads----------------------------------------------------------------any thoughts on what vortech pulley i should use or any other recommendations------------------thanks gary
Old Jul 12, 2011 | 12:48 AM
CAMSTER's Avatar
Default Heads....
I don't know wish metal in your block, i assume cast iron, if so good, for boost.
Now the heads you have are going to be the wrong core pieces to start, they will lift enough to loose you gasket seal and your motor will overheat in two blocks if you live home quickly, sorry to say but your quickest way here is to sell your heads now and go with minimum 5/8 thick deck heads, best yet, if you don't want to be restricted, just get the 3/4 thick deck heads, with 6 bolts per cylinder, then just have some body weld the receiving threaded bungs to the block, bingo you have a boost ready combination, if you have a lq4 or lq9 they are very easy to convert to 6 bolts, and i can help you with every thing you need, plus the info, all you need to do is to get somebody to weld it for you, if you don't know, i have the welding rods needed for the job, the bungs and a special 2" grinding wheel needed for the inner studs nuts clearance, i have all these things left over from my previous lq9 boosted build wish i converted to 6 bolts, i converted the heads as well, but is a lot of work for the heads conversion, to do the block all you need is the GM lsx 6 bolts head gasket to guide in placing the bungs for the studs, LMK, the stuff i have will cost you minimum. I know this is hard to swallow but i say ask those who know, like head porting chops and racers, you need to avoid the school of hard knocks, from the get go. It will be a heck of a lot shipper to avoid trouble and just go to the point, armed with the rite core pieces from the beginning. Best regards, Dave.
Old Jul 12, 2011 | 04:29 AM
catpue's Avatar
Default pulley
in your opinion whats so bad about the 243 heads,i ran them for a month without any problems before tearing down the motor only because the shop that put the super charger on did not pin the crankshaft,the crank bolt backed out and screwed up my crank and my pulley-------------------------thanks for your input
