Turbos to fit the following criteria
Looking for some decent turbos to use on a twin build for my C5.
To fit the kit I need the following necessities from the turbos:
-t3 exhaust housing
-5 bolt flange WITH wastegate hole
Something spec'd that could make 750 rwhp without pooping out.
-t3 exhaust housing
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic36191_1.gif)
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
no no, the flange on the DP has a hole for the WG, so you can run the wastegate into the flange. Like how the APS set-up runs.
__________________
You can see the downpipe flange needed I am referring to here. 5 bolt with the wastegate hole.... https://ls1tech.com/forums/forced-in...-possible.html
__________________
t3/t4 should be fine! 6262s come in the 5 bolt exhaust housing with WG hole? Where are you guys getting precision from or a good site to look up all their products?
__________________
