408 Twin Precision 6765 V&P Racing LSX Pinto
Car:
'79 Pinto 25.5 Chassis
All stock body
Original stock front suspension minus shocks & limiters
Stock rear suspension
Calvert Split Mono's
Caltrac Bars
Afco Sliders
Double Adjustable Shocks
Anti Roll Bar
Engine Specs:
LSX 408 9:1
Hydraulic 246/242 .640 lift
Trickflow 220 CNC Heads
Victor Intake/90mm TB
Turbo Specs:
Precision Billet 67/65 .81 T4
Precision 46mm Wastegates
Twin Precision 1000hp A2W Intercoolers
Fueling:
Magnafuel EFI 750
Precision 120# injectors
BS3 Engine management
Drivetrain:
TH400 - PTC Converter
8.8 Ford - 275 Radial
The car made 991 @ 6400rpm with 16#s of boost and 15 degrees of timing with the air fuels low 10:1.
It made 1209 @ 6500 with the 19#'s and the air fuels 10.6 -10.8. I was afraid to pull too much fuel before taking it to the track. It made 2-3 more pounds of boost at the track then at the dyno.
The car comes up on the brake like a blower car. I go on the brake off idle.
The car has been 1.250 60' and 5.22 @ 139 with only 19lbs of boost.
It has been 8.30 @ 172 but with only a 5.45 in the 1/8.
This is at 3200lbs. I'm going to pull some weight out of the car next week and bolt on some 76's and see what it will do.
All stock body
Caltrac Bars
Afco Sliders
Anti Roll Bar
Engine Specs:
LSX 408 9:1
Turbo Specs:
Fueling:
Magnafuel EFI 750
Drivetrain:
I was wanting to get it in the 7's with the 67's and I think it can still be done. Comparing some of my 1/8 mile increments to that 8.30 pass the car should be running in the 8.0's without leaning on it.
I just want to try the 76's to compare the two. Plus there isn't any class restrictions that limit me to the 67's.
From back in the 70/80s 1845 pounds half a tank on the fuel cell.
Your fast enough with that small a wheel base.
Put one through the woods on a 1/8th miles track.. Enjoy the car but be safe...
Still get tickled when someone makes fun of a pinto....
