camaro ls1 turbo at dyno
317 heads
60lb injectors
GT45 turbo
blow off valve Tial
Tial 42mm Wastegate
t56 transmission
Centerforce Clutch
433.77whp 447.05wtq @ 5psi
http://www.youtube.com/watch?v=zQtsR_jYJK8
can I get around 500whp @ 8psi
Temperature was 105 F at dyno day
Turbo: TC78
A/f 10.53
Timing: 9 degrees
Getting valve float...reason for the car being so rich.
My graph is here
https://ls1tech.com/forums/forced-in...you-think.html
You should start at atleast 12*. Too little timing can be as bad as too much timing.
....sorryps- You usually tune for a/f first...leaving timing down. Once boost and a/f have been achieved then you can bring up timing.
