Turbo Questions.......
Old Jul 14, 2011 | 08:04 PM
Camaro9969's Avatar
Default Turbo Questions.......
So i had a rear mount turbo........long story but anyways. i want a front mount turbo but curious what size turbo i should go with and how big can the stock bottom end hold on a ls1. Its basically a cam only car but i think doing a turbo would be a nice upgrade and a very good sound to add. Something different from a normal LS1. I want a procharger but that price is way too expensive i think i can build my own turbo set up for cheaper and get just as good of gains in hp. I have a 6.0 in the garage that i will be throwing in my car this winter and maybe i can swap this turbo right onto that??
Old Jul 14, 2011 | 08:13 PM
dschmittie1's Avatar
Well you can find used procharger kits for $3000-$3500 and if you buy just a head unit and braket you can peice a FMIC set up together and have a Procharger set up for even less. You will easily spend $3000 building you own turbo kit unless you use cheap junk parts
Old Jul 14, 2011 | 08:40 PM
Ping King's Avatar
How good are your fabrication skills?
I put mine together for a very reasonable amount. If you were to do truck manifolds and ditch the AC it would be even easier.
Old Jul 14, 2011 | 08:42 PM
turbocamaro125's Avatar
I've built a couple turbo setups for 3k and I don't used junk parts....if you buy junk you will be buying it again.
Old Jul 14, 2011 | 09:00 PM
Camaro9969's Avatar
I wouldnt use junk parts theres no point. I just am shopping around and seeing what route i should go, procharger, turbo, heads and Nitrous.....not sure really but will be something nasty. would like to get into the 10s by the end of this year
Old Jul 14, 2011 | 09:01 PM
Camaro9969's Avatar
I havent seen any used ones for that price but that seems very reasonable in that range and u get some good reliable power out of them
