Will this set up be a safe set up for my LS1?
Old Mar 1, 2004 | 10:01 AM
CVponYKillER's Avatar
Default Will this set up be a safe set up for my LS1?
DC-1 procharger 8-9 psi,cam,12 bolt,Stage 2 clutch
Its my daily driver, what do you all think? Will it be cool to drive this around and race on the weekends w/?
Old Mar 1, 2004 | 12:22 PM
Texas Terminator's Avatar
no prob. just get your fuel right.
Old Mar 1, 2004 | 12:41 PM
TWS's Avatar
TWS
I'm running a D-1SC at 8# on a stock internal motor with a good tune. No driveability problems.
You just say "cam". That tells us almost nothing. Your driveability will vary greatly depending on what cam you select.
Old Mar 1, 2004 | 03:14 PM
I know I said "cam" because I dont know which one I want to go yet haha.
Old Mar 1, 2004 | 03:18 PM
BIGBOS's Avatar
The cam plays a big part, if you plan on staying w/the stock shortblock for a while I wouldn't go over 220 for duration, stay with 114lsa to have minimal overlap......
8-9psi will be fine as long as the tune is on
Old Mar 1, 2004 | 11:58 PM
maybe i should be saving up for a 6.0liter iron block in the mean time eh? and run a more mild cam w/ s2 heads.
Old Mar 2, 2004 | 12:27 AM
BIGBOS's Avatar
Well with forced induction you will be fine as long as the tune is on......eventually you will be tempted to pulley down and step up the boost, things can potentially go wrong, its always good to have the motor idea in the back of your head when playing with F.I.
Old Mar 4, 2004 | 08:57 PM
brandon1221's Avatar
why are the 6.0L heads so popular?
