rearend mounted turbo
Old Jul 19, 2011 | 01:26 PM
snapper455's Avatar
Default rearend mounted turbo
we are looking at a 2002 Camaro ls6 and the turbo is mounted behind the rearend on the left side?? its a t76 does this work or how well does it work. seems like some real long plumbing would effect the turbos ability to function well.
Old Jul 19, 2011 | 01:36 PM
lynx853's Avatar
STS turbo is famous for this setup.... most people run a slightly smaller turbo then they would under hood to compensate for lag. The amount of piping back to the engine acts as an intercooler, although you can also ad an intercooler as well. Some people on here have good luck with them, some make their own rear mount setups. I'm not advertising for or against this setup, but it's just another option for forced induction. the other good thing is that since the turbo is after the cat, it SHOULD pass emissions if everything else is kept factory. I'm not sure weather or not its CARB certified, but it is another way to get hp in areas where what is a factor. IE Left Coast California =P
hope this helps answer your questions!
Old Jul 19, 2011 | 01:51 PM
XtremeDime's Avatar
It works alright. You do add alot more points of failure with a rear mount setup ie oil pumps. You have 1 pump that connect up front the engine so it can supply oil to the turbo, then you have a second pump that returns oil to the engine from the turbo.
They are a little more laggy then a front mount but they make good power and dont take up precious space under the hood.
Old Jul 19, 2011 | 03:15 PM
snapper455's Avatar
thanks for all the fast response. i am a little less reserved about this purchase now. a shop called LME built this setup.
Old Jul 19, 2011 | 04:01 PM
XtremeDime's Avatar
LME is sponsor on here, cant say Ive heard anything bad about them.
Old Jul 19, 2011 | 09:32 PM
20TA02's Avatar
if all the bugs are worked out... it can be a nice fun set up...
