Oil pressure dropping under load after oil change...
Old Oct 17, 2011 | 08:26 AM
Snyper's Avatar
Finally took my engine apart. All the bearings looked like the above picture excpet the bottom half of the thrust bearing and the bottom half of #4. They were completely wiped out with no coating left on the bearing. The only explanation for this could be the McLeod clutch I was running. It was way too tall(stack height of twin) causing too much load on crank.
Old Oct 17, 2011 | 11:56 PM
1SIKZ31's Avatar
Very interesting observation. (excessive load on crank)
Old Oct 18, 2011 | 11:55 AM
98Z28CobraKiller's Avatar
Restricted User
Check the crank for a bend. Also make sure to get the cap and line bore checked. My crank was bent .006 and my cap was damaged. Engine builder thinks that the cap walked on me due to using the stock main studs. I had a black lower half on the #4 bearing on mine.
Old Oct 18, 2011 | 12:51 PM
stevieturbo's Avatar
Surely that would have been blatantly obvious when fitting the engine to the gearbox ?
And also if this was the case, the clutch being partially depressed all the time would likely have slipped.
And for all the pressure it would be placing even if partially in contact, I doubt it would hurt the thrusts much at all. If it was in more contact, the clutch would have to be slipping, unless the engine makes no power at all.
Old Oct 18, 2011 | 05:19 PM
Snyper's Avatar
The lower halves on both mains were the ones completely copper. The crank is going in the trash since im building a sleeved 434ci NA motor with an LS7 top end. Im only reusing the block and rods...which were undamaged. The block is being checked at ERL before they sleeve to make sure everything is good.
Old Oct 18, 2011 | 05:23 PM
Snyper's Avatar
It was only .200" too tall.. And No, I couldn't tell because I was able to made the transmission up. It was only when my brand new clutch started to slip did I realize anything was going on. When I pulled it apart I took the requested measurements that McLeod asked me to and found out that the clutch stack was to tall. There is supposed to be at least .050 clearance between PPlate fingers and a fully compressed TOB. The constant pressure is the only thing I can think of that would trash the bearings like this since everything else was fine.
Old Oct 18, 2011 | 05:43 PM
A worn thrust bearing will not affect oil pressure as they only rely on spent oil from the main bearing anyway. And I dont see how a worn thrust bearing will cause main bearing failure.
Old Oct 18, 2011 | 06:48 PM
Snyper's Avatar
That's not true. A worn thrust bearing will do exactly what my car did. As you put load on the motor, it pushes the crank forward(and opens up on the thrust bearing relieving pressure) and caused the pressure to drop as the load increased. And the thrust is #3, and as my engine builder stated ,when one bearing goes out, it usually takes the next one out as well.
Old Dec 25, 2013 | 09:30 PM
justinkp's Avatar
I think I'm having the same problem :-/ new motor new clutch new turbo.
Old Aug 20, 2023 | 11:08 AM
Insttech427c5's Avatar
Was your clutch the issue that caused this?
Old Aug 21, 2023 | 09:56 AM
Black_Sunshine_99's Avatar
The last post on this thread was from 10 years ago, 12 years before that.
I'd start a new thread if you have questions.
