Is a forged crankshaft really needed?
Old Jul 20, 2011 | 11:06 AM
fireburr's Avatar
Default Is a forged crankshaft really needed?
I am in need of some help on a decision. I have just a bare block now and of course money is always an issue. I plan on going turbo in the future and putting down about 500-650 rwhp. I am going to be getting forged pistons and rods, is it really needed to get a forged crankshaft or anything else forged while I'm at it or can I use a stock crankshaft to save some money? Where are my weak points? Thanks
Old Jul 20, 2011 | 11:07 AM
Mike@Diablosport's Avatar
LS1Tech Sponsor
No...not needed at that power level.
Lots of people making a lot more power than that on a stock crank....
Old Jul 20, 2011 | 11:11 AM
Loudmouth LS1's Avatar
At that power level the stock crank is fine, I wouldn't even think twice about using it. As for other upgrades, it's always a good idea to do head studs and main studs.
Old Jul 20, 2011 | 11:15 AM
87silverbullet's Avatar
In the LS world and that power level, the machine work is more important than the choice in parts.
You can go past that mark with the stock crank with good machining. If the machining is poor you can really hurt some parts well below that power level.
Old Jul 20, 2011 | 12:42 PM
willizm's Avatar
I've been told that the stock crank can withstand over 1000hp or 1200hp. Can't remember which, but my intention is to hit 700+whp on a stock crank with forged rods/pistons.
Old Jul 20, 2011 | 12:55 PM
turbocamaro125's Avatar
idk how much it will handle but im building a 6.0 blocked 370ci motor now with stock crank and i will be pushing the limits of it for sure.....
Old Jul 20, 2011 | 01:53 PM
fireburr's Avatar
Thanks, that should save me a lot of money. Is there anything else that would be recommended to do besides forged pistons, rods, and stronger bolts while I have it down to the block. And what should I have done to the block, I bought it already honed with new cam bearings in it. If I buy a used crank will I be able to just drop it in?
Old Jul 20, 2011 | 02:23 PM
If you buy it used, I would take it to a machine shop to get checked out just to be safe.
Old Jul 20, 2011 | 04:11 PM
Larry @ AMS's Avatar
stock crank is fine as everyone here has mentioned
if money is an issue I would look for a complete stock 6.0 motor, do a cam pkg, rod bolts, head gaskets and studs. This will handle 600ish HP with no issues.
Old Jul 20, 2011 | 05:16 PM
02anti_vnm's Avatar
No stock is fine
Old Jul 21, 2011 | 07:42 AM
Reckless's Avatar
Super Moderator
Matt Harlan ran 8.29 at 170 about 7 years ago with a stock crank
Old Jul 21, 2011 | 08:00 AM
bravolistick's Avatar
823whp 877tq @ 20lbs on the stock crank, forged dimond pistons, eagle rods, head and main studs, hi flow oil pump, and YT 600 valve springs. The rest of the motor is stock! and she keeps making power.... GL wit your build, keep it simple
Old Jul 21, 2011 | 01:23 PM
fireburr's Avatar
maby i'll try a setup like that and have your kind of luck. How many miles have you put on it since that setup?
Old Jul 21, 2011 | 02:59 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
Which is extremely impressive!... It needs to be mentioned though that it was also a dry sump, aluminum rodded engine.
Old Jul 21, 2011 | 03:01 PM
I dont believe it to be luck. Meth and a sweet tune make it possible
also I dont drive around on 20lbs...( thats kill mode ) its usually @ 14lbs since I have 1 bar wg springs
Old Jul 30, 2011 | 01:54 PM
fireburr's Avatar
A little off the subject, but is a 5.3 crank the same as the 5.7?
Old Jul 30, 2011 | 02:03 PM
RX666's Avatar
even more ot here, but what is the SLP oil pump good to on my ls2? Im planning on a 370ci setup with oem crank with arp fastners, and a pt88 billet single setup along with quite a few other items. Is this oil pump a christmas ornament with my plans here, or can i still use it for what im doing with this? Im shooting for 850+whp.
